Quick question, bigger tires in rear
Old Mar 13, 2007 | 05:56 PM
JimboManJones's Avatar
Is it better to get bigger tires in the rear? My main concern is handling, will bigger tires in the rear help me take corners faster?
I am trying to determine whether or not I should get a 275/40/17 front and rear or 275/40/17 front and 315/35/17 rear?
Which would be better?
Old Mar 13, 2007 | 07:55 PM
Greed4Speed's Avatar
No you won't be able to take corners any faster with bigger tires alone. They'll also most likely reduce off the line traction due to shorter sidewalls and somewhat increased weight. You also SHOULD have wider wheels for them too.
The only things they'll do for you is look good, cost more, and possibly rub.
Old Mar 13, 2007 | 08:32 PM
Zepher's Avatar
Go with 275/40/17 Nitto 555RII's on all 4 corners. car will corner like it is on rails (as long as the rest of the suspension isn't sloppy).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
