Running New Fuel Lines
Old Mar 13, 2007 | 11:04 AM
Tourque's Avatar
I need to run new lines, stock lines are running way too close to my exhaust for my comfort. Any suggestions on the best way to do this?
I am assuming I'm going to be dropping the tank, using the compression-AN fitting pieces on each end (tank and fuel rail) to convert and plumb a new filter in-between.
Would be interested in any short-cuts that would allow me to not have to drop the tank. On the supply side I could just go from the fuel filter on up but not sure if there are any work-arounds for the return?
Any suggestions would be appreciated!
Old Mar 16, 2007 | 06:19 PM
blown383's Avatar
You an just use the compression fittings on the hardlines from underneath the car and re route the lines using stainless braided lines.
-B
Old Mar 19, 2007 | 10:28 PM
CDE's Avatar
CDE
You can cut a square out of the top of your trunk to access the fuel pump area if need be with a dremel tool.
Just an option
Clint
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
squarehead
Nov 21, 2014 08:02 PM
