Plugs too cold
Old Mar 11, 2007 | 01:59 AM
lt1 kenobi's Avatar
Plugs too cold
Ok.. I started spraying on my lt1... have msd opti, msd coil, msd wires, mallory box... Everything fine.. put in the autolite 104's gapped at .035.. and I have a slight miss like its loading up at idle... and at super light throttle usually around 2k rpms.... Any remedy... needs to be safe for a 150 shot.
Thanks in advance.
Old Mar 11, 2007 | 03:49 AM
Juiced91Z's Avatar
those plugs should be fine, allthough most go with the 103's or the NGK tr-6's. try changing the fuel filter, that might help a lot. And i noticed in your sig you have a jeff creech tune, from CAM right? where are you located? you should try RPM in Garner, WAY better tuning up there, Im in j-ville, check out our sight sometime. www.dragslips.com/jville
Old Mar 11, 2007 | 12:01 PM
2000GTP's Avatar
Sure its the plugs? Try putting in a stock set of plugs at the factory gap and see if the miss persists.
Old Mar 11, 2007 | 03:19 PM
lt1 kenobi's Avatar
The miss didn't start until I changed to these plugs.. so I know thats the problem.. that and my buddy did the same thing except w/ngk's on his mustang and same problem.
Old Mar 12, 2007 | 09:29 AM
Nitro Dave's Avatar
Make sure you did not crack the porclyn on a plug. Also make sure you do not have a bad plug wire. If what was said above about the 103s being the same as the NGK tr6 I would go to that plug instead.
Dave
Old Mar 12, 2007 | 09:58 PM
lt1 kenobi's Avatar
If the porcelan sp* on a plug was cracked wouldn't it cause the miss all the time?? Throughout the whole powerband? I belive the autolite 103's are even colder than the 104s.. I don't know what to do about this problem.
Old Mar 13, 2007 | 08:57 AM
Nitro Dave's Avatar
As far as the porclyn being cracked it could miss all the time or just at wide open throttle.
Just something to check.
Do you have a ignition box on the car?
Dave
Old Mar 13, 2007 | 01:05 PM
lt1 kenobi's Avatar
Mallory 685
msd opti
msd coil <--- thought the old coil could be the problem so bought this one. Same issue.
MSD wires.
EDIT: Never misses all the time or at wide open throttle... only at super light loads.. or no load.. idle... or say crusing w/your foot barely just resting on the pedal... press the pedal goes away.
Old Mar 13, 2007 | 10:12 PM
Nitro Dave's Avatar
Hmm puzzling.... Are you getting any codes?
Dave
Old Mar 14, 2007 | 09:39 AM
lt1 kenobi's Avatar
None at all..I'm wondering if at that light or no load area of the throttle is where the fuel has a chance to puddle slightly on the plugs.. causing the miss... Is there anything 1 heat range warmer that would be safe.... or if I gapped them a bit higher than 35.
Magenta_Hearts
Mar 29, 2017 08:54 PM
markzzzz
May 8, 2015 09:21 AM
greenzee28
Mar 26, 2015 09:13 AM
armedtrigger
Feb 24, 2015 08:30 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
