Lowering Springs affect ET?
Old Mar 5, 2007 | 12:43 PM
FivePoint7z28's Avatar
I've been thinkng of lowering my car lately but I was just wondering how they affect your ET at the drag strip. Because I do like to occasionally take my car to the strip, but I also like the look of the lowered stance. Any input would be appreciated.
Old Mar 5, 2007 | 01:09 PM
OBE1 95Z28's Avatar
Typically lowering a car can hurt transferring weight to your rear tires when launching, hurting your 0-60 time.
Old Mar 5, 2007 | 04:49 PM
Fast_Toys's Avatar
The biggest factor is when you lower your car, the rear control arms will no longer be parallel to the ground. This will hurt your traction. It can be corrected with the Spohn LCA relocation brackets we sell (part # SS210). They also have multiple mounting positions that allow you even improve your pinion angle over stock for MORE traction. They are a real bargin for 65.00 too
Old Mar 5, 2007 | 05:20 PM
I see. Those relocation brackets sound awesome. Just $65? You only have to buy one set right? Thanks for all the help!
Old Mar 5, 2007 | 05:43 PM
Fast_Toys's Avatar
Yes!
Yes you only need one set. They are a great bang for the buck (one of the best for your 60 foot).
Old Mar 5, 2007 | 05:50 PM
Thanks alot. You answered all my questions and be in contact with you in the next few weeks.
Old Mar 6, 2007 | 08:25 PM
SpeedDemon02SS's Avatar
i lowered my car and used the relocation brackets. no noticable difference at the track.
Old Mar 7, 2007 | 12:16 AM
Fast_Toys's Avatar
Brackets
Did you experiment with the different bolt positions to change the pinion angle?
What tires were you running?
If you didn't have enough available traction, no amount of pinion angle is going to improve ET's. However, going from stock to a positve pinion angle (which happens when you lower without LCA brackets) usually will hurt your 60 foots.
Old Mar 7, 2007 | 06:47 AM
I have the spoon relocation brackets. i used the lowest setting. its a tad on the negative side. I was running a 13.1 before, and am still - right around the 110mph mark. i never realy had that good of traction, and also, my clutch is slipping. need a bigger rear, new clutch, and some sticky tires.
Old Mar 7, 2007 | 10:44 AM
Fast_Toys's Avatar
There you go
You definitely need a working clutch and stick tires to get a good 60 foot time. LCA brackets should have no effect on MPH as that is an indication of the HP of the motor, not a function of traction.
Old Mar 7, 2007 | 05:15 PM
yup. the clutch is on its way, and i need a bit more money for the 12bolt before i can run with sticky tires.
Old Mar 9, 2007 | 03:20 PM
On my 3rd ten bolt and counting.
Old Mar 9, 2007 | 03:25 PM
Fast_Toys's Avatar
Ouch
Time to invest in one of our Moser 12 bolts!
Old Mar 11, 2007 | 01:16 PM
are the mosers a direct bolt in? i heard you have to weld some brake brackets on. how much for a moser 12bolt with abs/tcs and the auburn diff cover.
Old Mar 11, 2007 | 02:16 PM
Kredz28's Avatar
Plan on about 2,500$
