spray=head gasket
Old Nov 22, 2002 | 01:59 PM
Kyle@CSS's Avatar
spray=head gasket
just wondering
this is the 2nd time im having to change my head gaskets. is anyone else having problems?
Old Nov 23, 2002 | 02:39 AM
oil pan 4's Avatar
What kind of gaskets are you useing?
How much are you sparying?
Try and find the thinest ones with as many layers of compresed steel as you can get.
Old Nov 23, 2002 | 09:03 AM
Kyle@CSS's Avatar
The first one I used was a felpro. When it blew I went to hadwin white a local idiot dealership. and got a GM gasket. I replaced them. I did it in my front yard. I put it all together. It cranked up sounded good. I was adding water. I kept on adding. Then I checked the oil. I had water in my oil. Hadwin white gave me the wrong head gaskets. I was pissed. They ended up giving my new ones. Still wasnt happy because it was a job. I changed them again. Everything was fine. I just bought some more felpro ones. Hope fully they will hold.
I was spraying 150
Old Nov 23, 2002 | 02:01 PM
oil pan 4's Avatar
Moroso, the oil pan selling guys sell solid copper ones they say that those can't be blown but there around a $100 a set and you can reuse them 4 or 5 times.
Fel pro use to sell these super thin cyl. head gaskets that were only .009 inch thick ( thats = to about thickness of 15 sheets of paper) and had a compression volume of 3.2cc they cost about the same as regular ones too.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
