Rear End swap troubles....HELP
Old Feb 20, 2007 | 11:47 PM
zkmfdmz's Avatar
Angry Rear End swap troubles....HELP
I have a 1995 3.4 auto with 3.23
i am putting in a 1999 3.42 posi
i also have 17 in rims instead of 16
HOW do i program my tranny and PCM to recognize and compensate so my speedo and shift points are not WAY off
Old Feb 21, 2007 | 12:00 AM
Jared 3870's Avatar
The shift points will not matter, and your speedo wont be off too bad. Switching from 3.08s to 3.42s results in an 11 percent difference (at an indicated 100mph, you are actually going almost 90). With the 3.23s factory there wouldn't be enough change to warrant adjusting it in my opinion.
Old Feb 21, 2007 | 11:30 PM
3800FBL's Avatar
Running around without proper PCM input informarion can and will screw with the auto in that car. I'm not going to flame the above post, nor post a rolleyes, I'll just leave it at that.
Send an email to the guys at www.pcmforless.com, they will fully educate you on the matter.
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
