Another Bose Adapter Thread
Old Feb 18, 2007 | 06:36 PM
blunto's Avatar
With input from experienced members, I would like to clear up the rumors about the necessity of an adapter for an aftermarket head unit to work with an otherwise factory Bose system. Some say the adapter works, some say it sucks, others say it is completely unnecessary.
My setup:
Kenwood Headunit (16 Pin)
Bose Factory 3-Speaker System
I bought the wiring harness and antenna adapter, soldered everything up, but I have no sound at any of my speakers.
There are some unused wires on my harness:
From side coming out of H/U
ILLUMI
P. CONT
EXT. CONT.
MUTE
ANT CONT
From other side of harness
DIMMER
ILLUMINATION/DASHLIGHT
POWER ANTENNA
There is one disconnected wire coming directly out of the back of my H/U labeled:
REMO. CONT
What do I need to connect in order to avoid purchasing the aforementioned adapter? Do I need to bypass the factory amps? I do not want to replace my speakers at this time.
Thanks in advance for the help!
Old Feb 19, 2007 | 09:11 AM
PentaVolvo's Avatar
connect remote connect from your radio to power antenna wire and bam the amp should turn on and you will see the light :-)
Old Feb 20, 2007 | 12:40 PM
blunto's Avatar
Thanks for the help Penta I connected REMO. CONT (from H/U) to POWER ANTENNA (wiring harness) but unfortunately nothing changed.
I did not mention in the original post, but the H/U will turn on and is able to read CDs and read radio frequencies, there is just no sound.
Any input on the adapter issue? Penta, were you verifying that I should NOT need an adapter?
Thanks again!
Old Feb 20, 2007 | 02:39 PM
PentaVolvo's Avatar
Correct you shouldnt need an adapter at all. Did it work fine with stock radio. In the harness that plugs into the vehicle wires is there anything else u didnt hook up liek an amp turn on wire or something. Dimmer and illumination are of no concern so is there anything else left unhooked.
Try connecting the power antenna wire on the car side directly to where you have the switched 12volt ignition wire hookedup and see if that works. Theres no reason this setup shouldnt work if your bose is working properly.
Not to be stupid but you are turning the volume up on the cd player right
Old Feb 23, 2007 | 02:20 PM
Cam-aro's Avatar
Should just re-wire a BOSE system. It's the surest way to eliminate BOSE problems... those adaptors don't always work.
Old Feb 23, 2007 | 03:38 PM
seawolf06's Avatar
I think the wire out of my HU was blue and had to connect to an orange wire to get the amps to turn on. I may have that backwards, but that's how it was on mine when I had the same problem. The adapter address another problem entirely which you may or may not notice when the sound finally comes on.
Old Mar 16, 2020 | 09:36 PM
TylerTman's Avatar
Re: Another Bose Adapter Thread
Did you ever get a working fix for this? I'm having same issue
Old Mar 16, 2020 | 09:37 PM
TylerTman's Avatar
The orange illumination wire??
G-BODYT56
Jan 14, 2022 11:14 PM
GREEN3112
Feb 10, 2019 09:19 PM
n2oblkz
Oct 22, 2015 02:31 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
Bxlt1
Sep 10, 2015 08:16 AM
