91z stalling out
Old Feb 17, 2007 | 11:11 AM
72ccam's Avatar
91z stalling out
91z put vats by-pass in it after the ignition switch would not take the code in the key chip. when you drive it and it gets to normal operating temp the car will stall out. it will start back up and you can drive it. it stalls pretty much every time you come to a stop. only started after installing the vats by-pass. any suggestions would be appreciated. probably will install a new ignition swith and key if worse comes to worse. thanks
Old Feb 17, 2007 | 11:44 AM
Dave89IROC's Avatar
stalling has NOTHING to do with the VATS, VATS effects starting only(kills the starter and the fuel injectors)
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
