solid roller wiht stock heads (LT1)
Old Nov 19, 2002 | 07:12 PM
lt4 fd's Avatar
Solid roller with stock heads (LT1)
No real idea yet on the size cam I am going to use but its going to be a daily driver so its going to be on the small side for low end torque but still make power into the upper 6 thousands, when the heads are done. Just wondering what sort of improvements I would see from the solid roller alone, is it worth throwing in before the head porting or would it be more worthwhile to do it all at once even if I had to wait atleast a year? If the bottom end does need some refreshing I will be driving it with only a cam for a while if thats a good idea.
Old Nov 20, 2002 | 12:00 AM
lt4 fd's Avatar
Anyone out there with a setup like this?
Old Nov 20, 2002 | 07:39 AM
kmook's Avatar
Advanced Tech Moderator
I know Ed (Ed95Pont) runs a solid roller on stock heads. Maybe try to get with him for a recomendation, he is pretty good at cam help and suggestions.
Old Nov 20, 2002 | 08:49 AM
Jim S. '95 Z28's Avatar
A local guy (vulva) put down a tad over 400 RWHP with a solid roller and bone stock heads.
Old Nov 20, 2002 | 01:13 PM
lt4 fd's Avatar
Just curious but with a solid roller with whatever amount of power, would you get the same gas milage as any other car with the same amounts of power?
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
Brian-94TA
Jul 31, 2002 02:52 PM
