Chevrolet Volt Problem
Old Jan 10, 2007 | 11:37 AM
rlchv70's Avatar
Does anyone else see the potential problem with the Chevrolet Volt concept? It is supposed to be able to drive 40+ miles without using the ICE (internal combustion engine). Theoretically, if you only drove the car back and forth to work, you would never use the ICE.
However, as most of you know, gasoline will eventually go bad over time. Additionally, engines can deteriorate if they do not run for long periods of time. Engine oil can build up contaminants if the oil isn't periodically warmed up. If the engine is used sparingly or not at all for a long period of time, what happens when it does need to be used?
There could be a mandatory period of time that the engine must be used. However, this won't make some of the environmentalists happy.
Alternatively, there could be a service interval to change the oil AND gasoline. The engine would have to be designed for long term storage (similar to an emergency generator).
Thoughts?
Old Jan 10, 2007 | 11:41 AM
JasonD's Avatar
Admin Emeritus
While I am sure they have thought these things through, I think the pros of the program far outweigh those cons.
Not to mention, how long does it take for gas to go "bad" and under what conditions?
I think that under projected normal use, this wouldn't be much of an issue anyway.
Good questions, for sure!
Old Jan 10, 2007 | 12:19 PM
Josh452's Avatar
I wish u would have asked this yesterday...I could have gotten the answers! Interesting yes, but why would you put gasoline in the car to begin with if you're daily commute to work is less than 40 miles?
Old Jan 10, 2007 | 12:30 PM
Doug Harden's Avatar
Prominent Member
I think that most users would probably only plug the car in every other day, (laziness) and the gas engine would be used to make up the difference....JMHO
That or during a normal week, extended trips would kick-in the gas engine....it's that or Sta-Bil. OL!
Old Jan 10, 2007 | 12:34 PM
Ken S's Avatar
whats the cost of $/mile when running on electricity? For say, 10 cents a kilowatt?
Old Jan 10, 2007 | 02:17 PM
5thgen69camaro's Avatar
Thoughts?
It is a good question, but it would be an easy fix. Everything is computerized so if I were an engineer I would have it monitor the engine. If the engine had not been run in X number of days, I would have it automatically start and run through a full tank of gas, whether the battery was charged or not, while driving with a warning to the driver an hour or so in advance this was going to happen. I would also educate the buyers to expect this.
Old Jan 10, 2007 | 02:44 PM
rlchv70's Avatar
Under normal use, yes, but it has to be engineered to work in all situations.
I agree that this would be an ideal fix, but I see it being criticized by uninformed environmentalists if it did this.
Old Jan 10, 2007 | 02:46 PM
rlchv70's Avatar
Sorry, I thought about it yesterday, but didn't post it until today.
You would want to have gasoline in it for those "just in case" moments when you need the extra range. Also, you typically don't want to run the tank dry since it can overheat the fuel pump.
Old Jan 10, 2007 | 03:31 PM
Z28x's Avatar
For the Tesla roadster it is about 1 cent. Volt is a bigger car, maybe 2 cents? Don't forget gasoline prices are about 40% tax.
Old Jan 10, 2007 | 04:22 PM
Bert02SS
Guest
Posts: n/a
When the politicians figure out that electric cars a numerous enough, they will tax electicity with "highway taxes" and the like, just like gasoline and diesel. It's the way politicians think.
Old Jan 10, 2007 | 05:34 PM
Good Ph.D's Avatar
Seems an easy fix. I highly doubt most people are going to charge to completion every night and drive less then 40 miles.
Am I to assume that like the prius the electric engine is only useful for city driving? If thats the case its even less of a problem. If not a few lines of code could get the engine to run for a while if it hasnt.
Old Jan 10, 2007 | 06:00 PM
CaminoLS6's Avatar
Nope, your assumption is incorrect. The Volt is always propelled by the electric motor, the gas engine is just a generator to charge the batteries.
That's why this car is so different from cars like the Prius.
Old Jan 10, 2007 | 06:27 PM
Good Ph.D's Avatar
Interesting. At first the consensus seemed to be that electric motors ceased to be efficient at highway speeds. Suppose its not suprising that has changed.
Old Jan 10, 2007 | 06:57 PM
I doubt they would be screaming very loudly about an engine that rarely runs. They dont seem to complain about the hybrids which run all the time. In addition to that I think Gas stabalizer that is used to winterize boats and show cars would help if it really ran that infrequently. I think the best solution would be to force it to run every few days though.
Old Jan 10, 2007 | 07:05 PM
poSSum's Avatar
Disciple
I'll add "how does the heater work?"
