Pro shifter installed w/white hurst ball
Just installed my Pro 5.0. shifte with 50th anniversary white daytona hurst ball r and it obsolutely feels great. To all Fbody owners, Pro is the way to go. Below are pictures.
if you have the factory hurst in the SS you really only need a short stick. the factory hurst is a decent unit...not quite Pro-5.0 but it's pretty solid. the short stick makes the shifter really nice. been on my car for 5yrs and don't regret it at all.
I just saw the Pro 5.0 with the short stick in a "all in one" package on Afterthoughtauto.com ??? Would you recommend that?
I also have the hurst base with the short stick. Best mod i have ever done
I think it really want you wan to do. Teke is right about the hurst being a good shifter. But I just wanted to try out all the shifters. I just sold my Ripper which was a good shifter but wanted to try out the Pro Shifter and I like it. But really all of them are great, the short stick really matters though.
The stock Hurst is OK, but it had no positive stops and doesn't slide into gears like the 5.0.
Scof, you can cut a few threads off the 5.0 stick and have a short stick. No need to buy another. Mine was done when I got it since it was used.
"I just saw the Pro 5.0 with the short stick in a "all in one" package on Afterthoughtauto.com ??? Would you recommend that?"
if you already have the hurst from the factory...look for the small **** with H on the top...than i dont think the money is well spent. for $50 you can put a lou's shortstick on it and have a great shifter.
if you have the crappy base model shifter...the upgrade is worth it. the pro5.0 is considered by most to be the best shifter. so beyond that, its just what you're willing to spend.
usually you can find factory hurst shifters that people have removed for CHEAP. i paid $50 for mine shipped.
so the shifter plus the stick cost 1/2 what the pro5.0 costs alone.
personally i've only driven one car with the 5.0...and didn't like it. that was going from my hurst/short stick. the shifter seemed "stiff" and hard to move between gears. it was precise..but i had trouble shifting fast. most likely it just needed to have the springs loosened and for me to get use to it.
another side note:
i measured the shift throw on my crappy stock shifter/stick and 1-2 was about 8"
but with the hurst model and the lou's short stick it went down to 3.5" from 1st to 2nd.
i can now shift with my wrist...not my whole arm.
another side note:
F'n1996Z28SS
Aug 23, 2023 11:19 PM
94z28jbw
Sep 8, 2002 03:22 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
