Valve cover question!!
Old Jan 3, 2007 | 12:01 AM
94_camm's Avatar
I just got these valve covers but it doesnt look like thy would work with the gasket.they fit perfect on the head and bolt up but its just the gasket issue..is thier a different gasket i could use?(the lt1 valve covers have the lip at the bottom..these dont)
Old Jan 3, 2007 | 05:53 PM
Projectz28's Avatar
http://web.camaross.com/forums/showthread.php?t=493257
they look like the Summit covers. I just tried them and they didnt fit my heads. But if they fit your heads the gasket you need is listed under the "suggested parts" tab.
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 3, 2007 | 06:09 PM
94_camm's Avatar
thanks for the info..no thier not the summit one's but damn sure are close to it..thanks for the info ill try the different gasket which gasket should i get?
Old Jan 3, 2007 | 06:38 PM
Projectz28's Avatar
personally I like the felpro gaskets but I am sure the cheaper Mr Gasket ones will do the job.
Where did you get yours? What brand? I am still searching for a fabbed cover to fit my heads properly.
Old Jan 3, 2007 | 06:53 PM
94_camm's Avatar
i got them off ebay for 102 shipped!ill let u know how they fit with the gasket...and yeh i had to cut the bolt stems shorter!!
Old Jan 3, 2007 | 06:55 PM
mdacton's Avatar
They look like the same as the summit ones....no offence but probly made by the same people, made in china or something
Some one make Thick gaskets, its like 2 cork gaskets with a steel shim in the middle. don't remember who makes them but i know they are out there
Old Jan 3, 2007 | 07:01 PM
Projectz28's Avatar
Yeah I bet they are the same as the summit ones. They just dont fit my heads right. I called Summit last night and the Moroso cover that mdacton has are out of stock and they honestly dont know when they will be in. I'm searching for something else untill they are in stock. if I dont find anything else I will order them. Do yours have a rail on the bottom?
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
