Old 12-30-2006, 01:19 AM   #1
blackztpi
Send a message via AIM to blackztpi
fuel line routing options....
I want to run braided lines in place of my stock lines. i have the poor mans AN adapters to connect to the stock fuel rail kn the stock location. that works for me and my budget. BUT, i hate how the stock fuel lines run all the way across the top of the drivers side engine baye with giant "caution" stickers on them. Is there any sure fire way of routing the braided lines to make them look nice? pics please!!!! i can't find what i want in the searches
__________________
94 6 speed Z28
3.73 gears
UMI performance SFC's
clutchnet 6 puck ez lock pro clutch
358 cid 11:1. BRE/comp cam ground cam 230/236 with comp beehive springs, scat 4340 i beams, 4.045 Diamond forged -12cc pistons, gm forged crank 1.60 pro mags, 52mmtb, ported intake, stock heads. manley 1.94/1.50 valves, pocket ported, and 3 angle valve job. all rough castings blended. Pacesetter long tubes. hooker catback. Walbro 255. 30lb svo's big thanks to Bret Bauer!!! 363rwhp @ 6200 355lb.ft.@ 4700
blackztpi is offline   Reply With Quote
Old 12-30-2006, 02:36 AM   #2
Compstall
Compstall's Avatar
Send a message via MSN to Compstall
There is a company that makes a braided line kit for our cars. I still have the email at work from quite a while ago, but can't remember the name of them.
__________________
'94 Z28, M6, cam n' stuff (gone after 9 years!)
'05 GMC Yukon XL, 3/4-ton 6.0L Gas Sucker
http://www.cardomain.com/id/compstall
Measure with micrometers, mark with a scribe, chop with an axe..
Compstall is offline   Reply With Quote
Old 12-30-2006, 04:58 AM   #3
lethal93ta
lethal93ta's Avatar
Send a message via AIM to lethal93ta Send a message via Yahoo to lethal93ta
I didnt mind the stock location of where they came out, I made up a bracket and welded that fast and put 2 bulkhead fittings in there.
__________________
93 trans am ATI procharger 12.26 @ 115 MPH stock motor 9 lbs
now building a 383 9.0:1 stock LT1 heads ported and polished with 2.055/1.625 valves
ATI TH400 reverse manual w/T brake ATI treemaster MRT converter
Moser 9" spool 35 spline narrowed 2 inches a side 4 over all
Accel DFI Gen VII
lethal93ta is offline   Reply With Quote
Old 12-30-2006, 05:04 AM   #4
Very nice install. I like the addition of the bracket where they come through. I have a kit(that I have not installed yet) from http://www.performanceplumbing.com/FuelLineKits.html
It is a nice kit, but it does route in the same location as stock AND makes you delete the return.
chevroletfreak is offline   Reply With Quote
Old 12-30-2006, 05:07 AM   #5
lethal93ta
lethal93ta's Avatar
I needed that box out to get the angle right comming into the engine bay, if i didnt angle them down like that they would have hit the hood.
__________________
Accel DFI Gen VII
Old 12-30-2006, 09:47 AM   #6
Lethal, what did you do about a return line?
Old 12-30-2006, 09:52 AM   #7
lethal93ta
lethal93ta's Avatar
the small one there is my return line, I dont have any emissions on my car now so the third line that went back to the charcoal canaster is gone.
__________________
Accel DFI Gen VII
Old 12-30-2006, 11:25 AM   #8
Compstall
Compstall's Avatar
Yep, ^^^^ that's the company I was talking about.
__________________
Old 12-30-2006, 01:08 PM   #9
blackztpi
yeah, how did you get rid of a fuel return line? you'd have to convert to an integrated fuel pump/pressure regulator mounted in the tank like the new vettes. anyway, i like where the fuel lines come out of the inner fender from the factory.... i don't like how they route all the way across the top of the drivers side engine bay to the back of the fuel rail.
__________________
94 6 speed Z28
3.73 gears
Old 12-30-2006, 01:10 PM   #10
blackztpi
lethal, thats a decent setup but it requires that you run a really long vaccum line over to the regulator.
__________________
94 6 speed Z28
3.73 gears
Old 12-30-2006, 01:38 PM   #11
lethal93ta
lethal93ta's Avatar
Quote:
that didnt matter to me, its one of the only choices I had for a clean fuel line set up, Im just going to run a line around the fire wall up around the fender to keep that clean.
__________________
Accel DFI Gen VII
Old 12-31-2006, 01:36 AM   #12
Injuneer
Super Moderator
My braided supply and return lines come up right in front of the firewall, and are virtually invisible. The regulator is mounted under the cowl. The return line does come off the diagonal cross-over, so its not completely out of sight. The EVAP purge line has been eliminated.
__________________
Fred
94 Formula A3+1: 381/TH400+OD/N2O 11.1 @ 128 on a 125-shot
Detailed Mod's List - - - - Step into my office.... - - - - Trailer Queen......
Injuneer is offline   Reply With Quote
Old 12-31-2006, 10:13 AM   #13
mdacton
Premium Member
Send a message via AIM to mdacton
my supply comes up the pass side fire wall, rails run in series and the return goes to the reg and then a -6 return down the drivers side firewall
mdacton is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
