Brand New never used or installed LTCC with coils/tall valve covers! Must see-cheap
Old Dec 29, 2006 | 11:08 AM
regorih inHous.'s Avatar
im putting the car back to stock, so that means that I wont have the chance to install the LTCC! The LTCC is brand new and was never installed/used, im also including 8 coils that came off of a 1999 SS camaro. The coils are mounted on some Moroso Tall valve covers thats are also included. Im asking $520 O.B.O on this great deal. Below are some pics so you can see the LTCC, coils, and talll valve covers. FYI the passager side valve cover was modified with a hammer and torch to clearance it for the alternator.
As you can see on the brain of the LTCC it has no scaraches or signs of being installed. All it did was sit in my room
Trust me on, this valve cover looks bad but once the alternator is on you cant see anything. The heads are AFR 210 with 1.6RR and a cam that has close to .600 lift and I never had and clearance problems. The valve covers also clear the alternator. The hammer and torch seemed like the best solution because I dirent have to buy a bracket to relocate the alternator or compressor. Its a direct bolt on with no modification the your ac/alternator and I saved about $175 for the relocation brackets and most important, the head ache.
Old Dec 29, 2006 | 11:54 AM
Under_Pressure's Avatar
u got mail.
Old Jan 1, 2007 | 05:58 PM
bump to top
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 29, 2014 04:54 PM
