Old 12-25-2006, 01:01 AM   #1
Wildwill2855
injector swap
how long should i plan for an injector swap, and figure its about 30 degrees outside? 97z. i dont need a fuel rail disconnect tool do i? Dont i just pull the rail and remove the clips and they come out?
Wildwill2855 is offline   Reply With Quote
Old 12-25-2006, 01:24 AM   #2
solarofthesix
a buddy of mine did this in about an hour from start to finish.
solarofthesix is offline   Reply With Quote
Old 12-25-2006, 03:24 AM   #3
formulalt4383
a hour is about right if your new at this but pretty decent with working on cars. If you are a novice at working on cars as well as never did this before could take a little longer but its really about as easy as you can get.
Just remove 4 bolts (I forget the exact size but I think they are 8mm/ 5/16 off the top of my head). Remove the injector to harness clips by pushing in then grabbing at the ends and pull out of the grooves, then pry up on the rail with a flat head screw driver. wiggle it a little and it will pop off a injector at a time. Then slide the clips off the injectors , then wiggle the injectors out (the hard one's you might have to twist the injector so the harness end is under the rail then use the rail with a screw driver to pop it off. Then you can just install the new one's. Be sure to use a little lubricant of some kind on the o rings. It will help with the install. (no fuel line removals necessary).
Good luck.
formulalt4383 is offline   Reply With Quote
Old 12-25-2006, 08:34 AM   #4
2000GTP
Premium Member
2000GTP's Avatar
Its not a hard task to do, as mentioned above, it is very important that you lubricate the o-rings before putting the rail back in. As for how long it will take, some people who are very good at it can take under an hour. I wouldn't rush though, just take your time and do it right.
__________________
1997 Camaro Z-28
A4,3.23s,T-tops,Black,Leather
Pacesetter LTs,catted ORY,Magnaflow CB,Spohn suspension, NX dual nozzle w/ Gen X2 upgrade,Mad Z28 tune,Mallory 685
2000GTP is offline   Reply With Quote
Old 12-25-2006, 12:24 PM   #5
OBE1 95Z28
A little motor oil works great to lube the o-rings. Also blow off the intake manifold before you start to keep dirt/sand from falling into the injector holes.
__________________
2010 2SS RS IOM M6- on order
1995 Z28 - M6, Blown, intercooled and nitrous injected! Featured in Camaro Performers Magazine, May '05
OBE1 95Z28 is offline   Reply With Quote
Old 12-25-2006, 11:14 PM   #6
solarofthesix
Quote:
that is a MUST!
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
