Old 12-23-2006, 06:40 PM   #1
SS1156
SS1156's Avatar
Send a message via AIM to SS1156 Send a message via Yahoo to SS1156
Fuel gauge jumps around
I did a search and did not find anything specific to my problem. I was driving the car today and noticed that the needle in the gauge was jumping around quite a bit. I know that the sending unit is a float design but the needle was moving too much. Do you guys think the sending unit is going bad? The car only has 56k on it. If I need to replace it, can I get one with a walbro 255lph pump already in it? thanks for any help you all can send.
__________________
96 SS #1156: M6, Hardtop, All SS options including R1's, Spohn TA, BMR SFC & CM PHB installed. 383 stroker w/ an LE topend on the way.
1999 Yamaha R1: RIP thanks to a drunk driver
www.fquick.com/SS1156
"If god didn't want me to play with it, he'd a made my arms shorter"......Me
SS1156 is offline   Reply With Quote
Old 12-25-2006, 12:34 PM   #2
OBE1 95Z28
The sending unit and the pump are separate parts that mount next to each other in the tank. Your problem may be a wire issue; Shoebox has a troubleshooting procedure here: http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
__________________
2010 2SS RS IOM M6- on order
1995 Z28 - M6, Blown, intercooled and nitrous injected! Featured in Camaro Performers Magazine, May '05
OBE1 95Z28 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
