12-21-2006, 05:19 PM
Fuel pump access door panel problem. pics
my problem
WTF is that black line all the way to the left. i thought my fuel pump was leaking so i researched and cut a hole out and i kinda cut the top of that line. i wounder if thats where the fuel is comming out. HELP. all other lines are connected and i have no idea where it goes
__________________
1997 Z28 red convertable LT1 A4 find me in the 617
Times: 14.5 - 1/4 9.1 - 1/8  need to be faster.
"No FU*KING Apologizes" SRH
12-21-2006, 06:13 PM
Its a breather hose
12-22-2006, 10:48 AM
but wtf should it be connected to cause my car is filling up wit vapors and i can't take it. help
__________________
12-22-2006, 01:11 PM
well now its definitely gonna fill with gas fumes because you cut a hole in the sheet metal
__________________
94 Black Z28 A4 3.23, Pacesetter LTs, Exhaust ala MagnaFlow, 17" Chrome Z06s, LT4 KM, Madz28 tune, tbypass
12-22-2006, 02:33 PM
Ive always done the fuel pump the hard way,by taking the tank out  .toyota supra,pontiac bonneville,91 forumula firebird.sometimes its a pita.but sometimes it a breeze.later
12-22-2006, 03:16 PM
Super Moderator
Is it possible the vent hose from the canister to the engine had been removed from the canister and pushed back up over the fuel tank?
This is a 97, and there's no "extra" line:
http://www.cardomain.com/member_page...3_108_full.jpg
But.... look at the "upper" metal line, which you didn't uncover.... could that possibly be the hose that connects there, and its fallen off?
12-22-2006, 06:06 PM
I was doing this eariler on today, from left to right;
the 1st metal line connects to a quick connect
the 2nd one is connected as shown
the 3rd one connects to a quick connect
the 4th one takes a left hand turn then connects to a straight rubber pipe
that rubber hose is really weird
__________________
01-13-2007, 12:44 AM
just did my fuel pump today and i didnt see anything like that extra line you got there.
and i cut my access door a little bit more towards the back seat to get access to the quick connects.
best bet would to be to get a buddy to jiggle the line while you're under the car trying to see which one is moving. and double check that all four of your hoses are connected
__________________
1995 Z28 Must be sold...
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
