Old 12-21-2006, 08:25 AM   #1
19z28camaro02
19z28camaro02's Avatar
Send a message via MSN to 19z28camaro02
Lightbulb MSD Ignition coil?
I'm looking at getting the MSD Ignition coil for GM Cars (pn 8226), do i need the different wiring harness that SummitRacing says i do?
__________________
1996 Z28 T-Tops BUILT A4-Its quick when it runs right.
2003 Cadillac CTS Daily Driver
19z28camaro02 is offline   Reply With Quote
Old 12-21-2006, 09:04 AM   #2
WejaZ28
Mine was plug and play, no harness.
__________________
1995 Z28 All the goodies and spray.
1994 Cobra, intake and exhaust - don't hate.
1998 Z28 Flowmaster.
WejaZ28 is offline   Reply With Quote
Old 12-21-2006, 09:14 AM   #3
2000GTP
Premium Member
2000GTP's Avatar
You'll need the harness if you install the MSD ignition box.
__________________
1997 Camaro Z-28
A4,3.23s,T-tops,Black,Leather
Pacesetter LTs,catted ORY,Magnaflow CB,Spohn suspension, NX dual nozzle w/ Gen X2 upgrade,Mad Z28 tune,Mallory 685
2000GTP is offline   Reply With Quote
Old 12-21-2006, 09:27 AM   #4
19z28camaro02
any box or a specific one?
__________________
Old 12-21-2006, 09:42 AM   #5
shoebox
shoebox's Avatar
Quote:
That is not the coil you want for a 1996. You want the #8231, single connector coil. You don't need anything else just to replace the coil.
shoebox is offline   Reply With Quote
Old 12-21-2006, 01:43 PM   #6
19z28camaro02
it says that it is an OEM Blaster, i want the upgraded one, is the 8231 the upgraded one and just has a funny name?
__________________
Old 12-21-2006, 03:02 PM   #7
Sick97SS
I replaced the coil on my 97 to try and fix my high rpm miss. I also wanted to "upgrade" at the time but i couldn't find a MSD Blaster anywhere. All i could find was 93-95 Blaster coils. I don't think MSD even makes 96-97 upgraded coils. Did some research and everyone says there is no need to upgrade the stock coil anyways because it has plenty of juice for even high HP cars. Replaced it anyway with and OEM GM coil. But still didn't fix my miss, and probably never will.
__________________
1997 Camaro SLP SS, T56 The Sickness (webpage w/ mods)
2002 CBR F4i
Bike Page
Sick97SS is offline   Reply With Quote
Old 12-21-2006, 03:10 PM   #8
shoebox
shoebox's Avatar
It's the only one MSD makes for single connector applications. As was previously said, the 96-97 coils are pretty good as stock and installing the MSD one really won't do much for you.
Old 02-11-2007, 10:51 PM   #9
BTC
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
What about on a '94? Any advantage of the MSD 8226 over the stock coil? I'm going to be replacing my distributor and I'm wondering whether I should go ahead and get a new coil, wire & coil module? My service manual seems to make no reference to an Ignition Control Module. Would that be the coil module? Does MSD make one of those?
Anyway, do those parts wear out over time and would you replace everything while replacing the opti if the car was over 100K and had been sitting for an extended period?
__________________
Bill
'94 M6 Z28 That's Been Sitting For 8 Years. Coated Kooks 1 3/4" Race Headers, Kooks ORY, GMMG Exhaust, MSD 8.5 Super Conductor Wires, TB Bypass, !AIR, !EGR.
BTC is offline   Reply With Quote
Old 02-12-2007, 05:50 AM   #10
01Z
01Z's Avatar
The ignition module and coil are in a hot place. There are some instructions on how to move one or both a little off the cylinder head. It's never bad to reduce the high temperature to these parts. You might want to check shoebox's web site.
__________________
Camaro whisperer...
1995 Z28 A4 Onyx - ZEXn2o HyfireVI Hooker CB BadlanzHPE CO CAI SFC PaceSetter 160° HCK ScanMaster Harwood UZ SS Wing & wheels
2001 Z28 M6 NBM - LS6 H/C TimingTuner n2o WB SFC SLP LM & Lid CAI Pro5.0 ScanMaster 160° SS Hood-Wing ProStars Vogtland lowered
01Z is offline   Reply With Quote
Old 02-12-2007, 09:08 AM   #11
BTC
Thanks for the heads up on that, 01Z.
I may have spoken prematurely when I said the service manuals make no reference to an ignition control module, but they seem to use the terms ignition control module and ignition coil module interchangeably. I haven't seen an "ignition control module" referenced in any diagrams, but they do refer to an "ignition coil module".
Anyway, what other ignition components would you seasoned professionals change out while replacing an opti? The coil & control module aren't that expensive and I'm curious whether you guys think it would be a good idea to replace them while I'm in there. I guess the MSD Control Modules are their ignition systems and I'm probably not interested in going that route, but I would consider an OEM control module and MSD coil & wire. Or, would I be better off going OEM across the board? Does anyone know if the MSD coil comes with the grease pack referenced in the service manuals?
Thanks.
__________________
Bill
Old 02-13-2007, 10:32 AM   #12
mzgp5x
I run a MSD blaster 8202 with a 6a box on a 97SS 383 LT1. The blaster coil is much larger than the stock coil. I attached the coil+bracket near the water pump drivers side of block to 3/8 fastener on the head. The coil wire fit easy to the optispark. Mounted the 6a on the front rad support drivers side. Also, I used the MSD 6a wire interface harness, and, also run a variable timing control. I moved the PCM coil trigger to the driver side fender (lengthened the wires). The air pump was relocated deep in the drivers side motor compartment (had to move due to D1 mount).
mzgp5x is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
