Old 12-20-2006, 09:23 PM   #1
mrmint69
mrmint69's Avatar
Bigger injestors?
I have the factory injectors. Is there a bigger size i can get without having to get the computer reprogrammed?
__________________
1994 Z-28 LT1 A4, Powerdyne Supercharger 6 psi, 3.73 Gears, GMPP 1.6 Rockers, LT4 Springs, 42LB injectors, PCMFORLESS, All MSD ignition, Inline fuel pump, SLP sub frames, Panhard Bar, strut bar and rear control arms & LCA relocation, 1LE sway bar, Mid pacesetter's. 3" exhaust to Jegs electric cutout. Nitto NT555R Extreme Drag Radial 275/40R17
mrmint69 is offline   Reply With Quote
Old 12-20-2006, 10:17 PM   #2
lethal93ta
lethal93ta's Avatar
Send a message via AIM to lethal93ta Send a message via Yahoo to lethal93ta
no matter what injectors you put in you should program for them.
__________________
93 trans am ATI procharger 12.26 @ 115 MPH stock motor 9 lbs
now building a 383 9.0:1 stock LT1 heads ported and polished with 2.055/1.625 valves
ATI TH400 reverse manual w/T brake ATI treemaster MRT converter
Moser 9" spool 35 spline narrowed 2 inches a side 4 over all
Accel DFI Gen VII
lethal93ta is offline   Reply With Quote
Old 12-21-2006, 02:38 AM   #3
ajlew9428
what he said
__________________
94 Z28 A4 kn cold air intake, taylor otvc plug wires, pacesetter LTs, Ory, magnaflow catback, !AIR!, !cat!, !egr!, B&M tranny cooler, msd coil, strange 373, eaton posi, 160 thermostat,crane gold 1.6 rr, lt4 valve springs,lt4 KM,pcmforless.com tune
http://www.cardomain.com/ride/2489368
ajlew9428 is offline   Reply With Quote
Old 12-25-2006, 10:26 AM   #4
mzgp5x
I have gone to 30#/hr with the stock PCM flash (Hypertech). It ran OK. When I went to 36#/hr, the car runs rich due to a PCM cal of 24 in the flash. Very difficult to start. I purchased LT1-edit. Now running 72#/hr Low-Impedence Siemans with an Acceleronics driver box. (1997 - 383/D1)
mzgp5x is offline   Reply With Quote
Old 12-25-2006, 11:26 AM   #5
lethal93ta
lethal93ta's Avatar
go ahead and run 30s on stock programing, wash the oil off the cylender walls and take the rings out from to much fuel. running rich is just as bad as running lean.
__________________
Accel DFI Gen VII
Old 12-25-2006, 12:38 PM   #6
OBE1 95Z28
Quote:
Dynoing tuning of a blown car is cheap insurance to keep the engine healthy. I would get a set of 42 # injectors and have the car tuned.
__________________
2010 2SS RS IOM M6- on order
1995 Z28 - M6, Blown, intercooled and nitrous injected! Featured in Camaro Performers Magazine, May '05
OBE1 95Z28 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
