Old 12-23-2006, 02:42 PM   #46
95 Z/28 LT1
Super Moderator
95 Z/28 LT1's Avatar
What about injecting nitromethane and water?
__________________
1995 Camaro Z28 Convertible
2003 Corvette Z06
2008 VW GTI
95 Z/28 LT1 is offline   Reply With Quote
Old 12-23-2006, 02:49 PM   #47
engineermike
Quote:
Originally Posted by 95 Z/28 LT1 View Post
What about injecting nitromethane?
That's sort of like injecting Nitrous. The discussion here centers around using water or methanol to reduce the chance of detonation and make the engine safer. Nitrous and nitromethane will not accomplish these goals.
__________________
'95 Z-28
388, AFR 210 Heads, Comp 224/236 cam
Home-built T-76 GTS turbo setup
TH350 & Vigilante 2400
engineermike is offline   Reply With Quote
Old 12-23-2006, 03:00 PM   #48
95 Z/28 LT1
Super Moderator
Ok then, nitro and water. Or nitro, methanol and water?
__________________
2003 Corvette Z06
2008 VW GTI
Old 12-23-2006, 10:54 PM   #49
Julio
Sounds like a plan.. go for it.. let us know how it goes
__________________
1989 TTA 10.55 132.68
www.alkycontrol.com
70 1/2 Camaro SS**RIP**
July 2001 Super Rod
530 RWHP 6.80@103
Julio is offline   Reply With Quote
Old 12-25-2006, 02:58 PM   #50
Schurters LT1
1 rule of thumb, when an alky funny car can run faster on water i will switch...until then 100% meth
__________________
Harshaw Racing Engines 355, Accel DFI Gen 7 ,Vortech T-Trim' custom 4" intake pipe, Bret B Custom blower cam, Alky control kit, Larger FMIC,
The lil ole LT1 just put down 686rwhp and 590rwtq!
http://videos.streetfire.net/video/9...2200b23723.htm
http://client.webshots.com/user/jschurter
Schurters LT1 is offline   Reply With Quote
Old 12-25-2006, 09:09 PM   #51
Schurters LT1
No
__________________
Old 12-25-2006, 09:26 PM   #52
Schurters LT1
LOL hey i am happy running 100% meth......
__________________
Old 12-26-2006, 01:34 PM   #53
Schurters LT1
Quote:
Originally Posted by mgray View Post
That's great, you are one circumstance. As Mark pointed out, water injection isn't simply for auto 6 and 8 cylinder engines. Arguing an entire concept and theory on such a small set of circumstances is questionable. It might very well be that these engines operate behind or beyond the practical purposes of water injection, but that still does not invalidate water injection as it relates to internal combustion engines.
The system that has been outlined by most of you all is merely a supplemental fuel injection. This would be nearly the same as injecting or running 100% race gas. If I put water in my gas tank and said, "man it sure runs better on straight pump gas," you would call me an idiot. I passed similar judgement on your post.
Just putting out there what works for me I love my alkycontrol kit and Juilo has been nothing but great help,
Like allot of people pushing big numbers there is allot of money in these set up's and i want it to last a long time...if Juilo can get a Turbo T/A to last @30lbs of boost on stock block on 100% alky ..that's all i need to here....
__________________
Old 12-26-2006, 02:14 PM   #54
rskrause
rskrause's Avatar
Send a message via AIM to rskrause
Yep, I bet any of our cars would run better on straight methanol than on any combination of gasoline and water, water/methanol, or straight methanol injection. Unfortunately, that isn't practical and doesn't shed any light on the subject anyway. The principles of the IC engine have not changed since WWII. I advise those of you who are sincerely interested in this topic to go back and look at the original research on boost fluids. They decided on a water/methanol mixture. Go figure?
Rich
__________________
'95 Z-28 383: Procharger, nitrous, etc. BBC 27T race car. "Every man dies, not every man really lives" William Wallace (Braveheart)
rskrause is offline   Reply With Quote
Old 12-26-2006, 02:44 PM   #55
markinkc69z
I have downloaded probably close to 60 papers that pertain to performance and forced induction with the bulk of the research done in the 40's. When I was is my teens and early 20's I would have probably ignored this stuff because after all its 60 plus years old. Now with more experience I realize that what used to work still does. Water is still water, methanol is still methanol and boost is still boost. About the only thing that is different about some of these airplane engines is that they run lower compression and rpm than we do, but they're also operated at max or near max load for extended periods of time and many are aircooled.
These engineering studies were done with the utmost seriousness as our air superiority was at stake. Most of these at one time were restricted access at minumum as the government realized the importance of the information. Nearly all studies you'll read mention detonation-limited performance as that is the stumbling block.
In an area where every pound counts if straight methanol was appropriate they would have used it because its 25% lighter than water. They of course found that methanol is prone to pre-ignition (where if you were to remove spark the engine would continue to run) and pre-ignition is particularly bad in a boosted engine as an intake "backfire" can have serious consequences.
I should mention outright that I never emailed Julio for the FAST logger files because I know their limitations and they won't include temp data other than a single IAT, there just isn't a way to hook up auxilliary thermistors to a FAST.
I doubt many here already running straight methanol will change their setup due to a post, but my hope is that people new to water injection will understand why a 50% mixture is both safer and more effective at controlling detonation than straight methanol. Don't run methanol because it sounds cool. When you do something, do it for an informed reason.
__________________
Mark Andereck
markinkc69z is offline   Reply With Quote
Old 12-26-2006, 03:25 PM   #56
Schurters LT1
What it comes down to guys, we all are going to run what we feel is right....There is allot of great info on here. I am happy with my meth, Rich is happy with his 50/50 mix...
__________________
Old 12-26-2006, 06:19 PM   #57
Julio
I think the engineers in this thread are bench racing with injection.
Vs guys like myself and Schurters LT1 have used it with positive track and dyno results.
So do you believe papers.. or do you believe real world results. Argue what you will.. 1,000's of cars running 100% straight methanol injection with positive results. For what ever the reason.. Is what it is. When you tune something with some balls on it once.. you never go back to water anything. Never.
I have never had a shop tell me ya know we tried this(straight methanol) and found water worked better. Lidio from Alternative was so in dislike from the water systems he had done, it was like getting a crowbar to get him to try 100% methanol or any other injection system.. why becuase of the issues this thread is about. And the information contained wherein. Once he tuned his first car on straight meth injection... he never looked back. www.alternativeauto.com he actually made an article on the fact.
Its really simple.. put you car on some rollers.. a few hours latter you will know the truth. This is assumming you can tune your ecu and have the facilities/resources to do so.
If not.. stop with the poison. Until you have the raw data.
__________________
www.alkycontrol.com
July 2001 Super Rod
530 RWHP 6.80@103
Old 12-26-2006, 06:33 PM   #58
BMWKillR
Quote:
Originally Posted by will62085 View Post
cool stuff...but curious, whats wrong with the term alky injection? isnt that short for alcohol (methanol) injection?
actually alcohol in most would be much more associated with ethanol than methanol, but both are alcohols. I don't know if people use ethanol injection or not.
__________________
94 M6 Z28 hardtop, Vortec S-trim blower (running 11lb pully), Fully forged internals, borla catback, FLP headers, ORY, QTP cutout, richmond 3.73's, Comp cam, 42lb Injectors, 52mm TB, Crane fireball ignition box, LT1 scanmaster, Strano swaybars, eibach prokit, adj. phb, sfc's, zr1 rims, nitto 555 275's...SS hood etc.
91 Celica GTS liftback (winter car/days when i can't drive the Z)
BMWKillR is offline   Reply With Quote
Old 12-26-2006, 06:59 PM   #59
engineermike
Quote:
HEY! I take offense to that!
Isn't one DSM guy running 45 psi boost with alky/pump gas? I think that should be the benchmark/poster child for 100% Meth. To anyone advocating the use of 50/50, that is your challenge. Get 45 psi boost safely with 50/50+pump gas, then I'll change my mind.
Mike
__________________
'95 Z-28
Old 12-26-2006, 10:05 PM   #60
rskrause
rskrause's Avatar
Julio: I think I spend as much or more time on the dyno and at track as most, if not more. Like I said, I guess we are going to have to agree to disagree on this one.
Rich
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forums Directory
