01 Z28/SS FS (Tons Of Mods) Have All Receipts
Old Dec 18, 2006 | 12:27 PM
Bill'sWS6's Avatar
There is about 18k+ invested in this car + the price of the car.
I have every receipt, dyno graph, window sticker for this vehicle.
My asking price is $19,900 which I believe is pretty fair.
This is a list of modifications:
I'll keep adding to this as I go through all receipts.
2001 Z28, A4 w/TCS W/ T-Tops
Moser 9" W/3:89 Gears
Light Neutral Interior
Glass Defroster
All Power Accessories
Monterey Maroon Metallic
Approx 28,000 miles placed on car
Wheel/Tires
ZO6 Motorsports 17X9.5 all the way around (extra set of Fikse FM5's 17x9.5) Goodyear GS-D3's
Interior/Exterior
Philips Ultinon 6k HID Bulbs
Philips Ballasts for HID system
Polished Aluminum Ballast boxes
PIAA 004x Driving Lights
PIAA 55w H3's, Ion Crystal
OEM SS Hood installed; still have original Z hood
OEM SS Spoiler installed; still have original Z spoiler
SLP Grille
SLP Floor Mats
SLP Deck Mat
Hidden Wire Modification - Passenger Side
Z06 Gauge Cluster (checkered pattern); Trans Am Bezel
Autometer Trans Temp (carbon fiber), custom mounted in center console.
Custom Front/Rear Leather Seats (OEM Color Scheme, 2-tone)
Front Seat Heaters (2 heat settings)
All MBA satin finish fluid caps
Madico Window Tint (lifetime warranty)
Jantzer Custom Powdercoated Maroon
- Lingenfelter Power Steering Pulley
- Power Steering Bracket
- Valve Covers
- Timing Chain Cover
- Alternator Brackets (not installed)
- Head Plate (Chevy Emblem)
- Thermostat Housing
Suspension/Braking/Rearend
Moser 9" Rearend W/3:89 Gears (3,000 miles on the rear)
Performance Alignment
Black Sphon Adjustable Tq Arm.
Black BMR Lower Control Arms
Black BMR Boxed Subframes, Welded
Black BMR 32mm Front Swaybar
Black BMR 21mm Rear Swaybar
Hotchkis Polished Alum STB
Bilstein Tuned Suspension 1.5"
Custom Baer Track System - Front Calipers
- Black Powdercoating Caliper & Bracket; White Lettering
- Stainless Brake Lines
- 13" 2 Piece Front Rotors, Polished Alum Hat
- Drilled, Slotted and Zinc coated
- Baer Eradispeed rear rotors, Drilled, Slotted and Zinc coated
Engine/Induction
SLP Lid & QTP Motorsports Bellows & KN Filter
Katech Belt Tensioner & MBA Pulley
Absolute Speed 1x Heads Milled .030, 10.8:1 compression
Fast Toys Ram Air Kit
Comp Chromemoly Pushrods (stock length)
Comp Titanium Retainers
Comp 918 (Blue Stripe Ver) Valve Springs
FAST LSX Manifold 78mm/All New Seals
FAST LSX TB 78mm (New Ver), Custom Polished - Mirror Finish
LS6 PCV System, LS6 Valve Covers w/new Seals
Thunder Racing 224.224 563/563 114lsa
Thunder Racing Coil Relocation Kit
Rollmaster Double Roller TC
Thunder LS6 Modified Oil Pump/New O-Ring
Nasty Performance Polished Fuel Rails and Fuel Pressure Gauge
Bassani Coated Mid-Length Headers & Y-Pipe w/Cats
Corsa Performancec Exhaust w/ Premium Tips
Meziere EWP (Satin Finish)
ASP Crank Pulley w/ARP Harmonic Balancer Bolt
Canton Oil Filter - reusable (change micron filter)
Canton Fuel Filter - reusable (change micron filter)
EFI Live Dyno Tune
Russel ProRace Braided line - Coolant Xover to Radiator
Russel ProRace Braided line - Coolant overflow
Russel ProRace Braided line - PCV to TB
NGK Iridium Plugs Gapped .050
GM Performance Wires (Red), Stock Heat Shields Polished
Gates Serpentine Belt
Lingenfelter/Samco Silicone Hoses (upper/lower radiator)
Ported and fully Polished MAF ends.
Hosetechnique MAF/TB Clamps - Fully Polished
Fluids
Redline 10w/30 Oil (changed 6x)
Redline 75w/90 gear oil (changed 2x)
Dexron 3 (changed 2x)
Redline Water Wetter - Fresh
Transmission
Transformace Racing Trans W/Zpack racing clutches (1,000 miles of trans)
TransGo Shift Kit (2 shims)
Fudddle 3800 Converter w/ 2.5str
B&M 19000 GVM Cooler (Front mounted)
Audio/Video
GM OEM Power Antenna
Alpine F752 5 Channel V12 Class T Series
Custom Amp Rack - allows clearance for t-tops
Alpine CVA-1005 In Dash Video
Alpine CHA-S634 6-Disc MP3 Changer
Alpine NVA-N751 Navigation Unit (Map for Southern Region)
Latest Navigation Map
JL 10w3 Mounted in JL StealthBox
MB Quart PSC-216Component (front)
MB Quart RKC-116 (rear)
DEI Permiter Alarm wired to OEM Alarm System
Optima RedTop Battery w/Warranty
All steering wheel controls maintained - PAC SWiX
The most recent Dyno numbers were 430/RWHP 410/RWTQ. The car has has run 11.98 at 116MPH with a lot of wheel spin. The car should run 11.7s with good traction.
Here are some pics of the car. I will try to get more posted ASAP.
http://www.villagephotos.com/pubbrow...der_id=1713718
http://www.villagephotos.com/pubbrow...der_id=1720431
Thanks,
Bill
Old Dec 18, 2006 | 04:52 PM
96_Camaro_B4C's Avatar
Sounds pretty badass!! Except for the girly A4, that is...
Links didn't work for me though.
Old Dec 18, 2006 | 06:44 PM
Bill'sWS6's Avatar
LOL, Got to love an A4 with a sleeper cam that runs in the 11's.
I fixed the links above so you can see if it is as bad *** as it sounds.
Thanks,
Bill
Old Dec 18, 2006 | 08:34 PM
transamgirl95's Avatar
very sharp looking car...i have yet to understand why someone would rag on it being for an A4 ...
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Hal Fisher
Sep 30, 2015 09:03 PM
95blkss
Sep 22, 2015 03:18 PM
DelSoto
Sep 19, 2015 05:31 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
