Old 12-12-2006, 03:42 PM   #1
94_camm
alittle trouble putting fuel pump in
Ok..Everythings done i just cant get that white strainer on the bottom of the bucket...any tips?94 lt1
Also any good way on getting the gas out of the tank?
__________________
1994 Camaro-383 Stroker
94_camm is offline   Reply With Quote
Old 12-14-2006, 03:30 PM   #2
mzgp5x
I have a 1997, and, there is a red wire near the passenger side PCM area. Connect this to 12+, and the fuel pump will run. Thus, you can empty the tank with the fuel delivery line dumping to a gas can.
Also, I had the same problem with white filter (on Walbro 255lph), so, I did not use it. I cut a hole in my rear pan, so, it's easy to remove the fuel sending unit. Last time I had the unit out of the tank, there was some particulate matter held by the fine mesh screen. I cleaned it off. Both pumps still running fine. 97SS/ 383 - FI/ dual Walbro in tank.
mzgp5x is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
