12-09-2006, 03:15 PM
mabe fuel pump..idk
__________________
94 Trans am.freshened LT1 with pacesetter LT's, msd blaster coil, k&n fipk. relocated IAC, icm mod,ac delete, ! air !egr 52 mm bbk, hooker catback. richmond 3.73. built 4l60e. bmr lowering springs, lca's, panhard bar, strut bar, strano bilsteins. all poly bushings 30/21 sway bars.
12-11-2006, 10:01 AM
A fuel pressure gauge indirectly checks volume. Tape the gauge to your windshield and watch the fuel pressure as you drive at WOT. If the volume can't keep up, you fuel pressure will drop off.
__________________
2010 2SS RS IOM M6- on order
1995 Z28 - M6, Blown, intercooled and nitrous injected! Featured in Camaro Performers Magazine, May '05
12-11-2006, 12:22 PM
thank you....i just bought a guage and will do that now. i have also notice that whizzing sound is more pronounced and getting louder. ill post my results sometime soon
__________________
12-13-2006, 10:52 AM
just had it tested... fuel pressure is at 34 and steady, should be at 41-47
__________________
12-15-2006, 02:22 PM
Just to be clear, 41 - 47 psi is for WOT, 34 psi for part throttle driving is normal. Your fuel pressure regulator has a vacuum line that adjusts the fuel pressure based on manifold pressure (vacuum). Part throttle driving has a higher vacuum than WOT (low vacuum, nearing atmospheric pressure).
__________________
12-15-2006, 06:32 PM
wide open it didnt change...so i just had it replaced. works good now
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
