Help me name this part... (exhaust)
Old Nov 25, 2006 | 03:34 PM
dtp's Avatar
dtp
There's a metal bracket (held in place by a couple bolts) that holds what appears to be a oval shaped rubber bushing that supports the exhaust on the rear right of my 98Z (the exhaust has a metal tongue that goes into the center of the bushing for support). This bushing is deteriorating and my car sounds like a bag of cans going over bumps which tells me my exhaust is bouncing around.
Anyone know the name for this part?
Old Nov 25, 2006 | 09:56 PM
Greed4Speed's Avatar
Its an exhaust hanger. Just tell them you need the rubber bushing for it. A parts store or exhaust shop should be able to hook you up.
Spray WD40/PB oil or the like on the new one for easy installation, or even the old one to pull it off.
Old Nov 26, 2006 | 08:27 PM
dtp's Avatar
dtp
Thanks!
Old Nov 29, 2006 | 10:02 PM
dtp's Avatar
dtp
Exclamation
Every parts store I went to did not have the part. Any good online places?
The 'exhaust hanger' I'm looking for is the rear right, not the one that hangs freely, but the bushing that is held in place by a bracket that supports a 'tongue' coming from the exhaust.
Old Nov 29, 2006 | 10:36 PM
PSU 98's Avatar
If it's a GM part there's probably a part# imprinted on it that would help if you wanted to order it from a dealer. I might be able to give you a part#, but I don't know exactly what you're referring to. A pic would help a lot here
Old Nov 29, 2006 | 11:06 PM
dtp's Avatar
dtp
See the rubber bushing right below the word 'flange' in the huge picture? That's what I'm looking for. I'm not much of a car person so maybe it has nothing to do with the exhaust... I just saw it there and thought that the 'tongue' moved when I shook the exhaust.
Old Nov 29, 2006 | 11:26 PM
PSU 98's Avatar
Yep, it's the exhaust hanger. I looked through my Camaro parts list and I still couldn't find a part#. If you can't find a part# on the hanger itself I'd just go to the GM dealer and have them look it up, it can't be more than a few dollars.
Old Nov 30, 2006 | 11:43 PM
black97lt1's Avatar
a parts store might not have it but an exhaust shop probably will
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
rapom
Jun 11, 2015 09:36 AM
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
