What caps to block off AIR on Pacesetter LTs
Old Nov 22, 2006 | 01:32 PM
69gto96z's Avatar
I am wanting to install my Pacesetter LT's this weekend and remove my AIR. What kind of a cap do I need for the headers? It will need a cap, I found one au Ace Hardware but it is made out of brass and I am aftraid the exhaust heat will melt the brass.
Old Nov 22, 2006 | 01:37 PM
CamaroRacing12's Avatar
<< same ? here
Old Nov 22, 2006 | 01:50 PM
LT1 POWR's Avatar
It won't melt. I have the same brass fittings i found at menards. I put some RVT sealant on the threads before i screwed it on. As long as it fits, use it.
Old Nov 22, 2006 | 01:54 PM
69gto96z's Avatar
Awesome, I guess I will give em a try. They are standard fittings and not metric, but they fit just fine.
"You save big money at Menards!"
Old Nov 22, 2006 | 01:57 PM
seawolf06's Avatar
What size exactly?
Old Nov 22, 2006 | 02:00 PM
69gto96z's Avatar
I dont remember exactly, I was in a hurry. But I think they are 5/8"s. I will post back in here later when I go buy em and give the size.
Old Nov 22, 2006 | 03:44 PM
pddye11's Avatar
you need a 5/8" standard flare thread cap it would be in a plumbing gas flare fitting. Anderson metals makes a good brass cap that isn't bulky at all. Support your local hardware store (true value)
Old Nov 22, 2006 | 07:52 PM
Spitfire557's Avatar
I cut the AIR tubing and took off the original nut type thing that screws into the header. Then I welded it shut and screwed it back in. Works like a charm!
Old Nov 22, 2006 | 09:59 PM
LT1 POWR's Avatar
Yeah, I tried true value first, but supriseingly they didn't have it. So I went into Menards, I didn't know the exact size, so I just took my old manifold in with me and tried caps until I found one that fits.
Old Nov 23, 2006 | 01:33 AM
69gto96z's Avatar
Yeah its a 5/8". I bought two caps, and one fit perfectly and this other one was just a little bit longer so I just used some plumbers tape on the threads and am hoping it bottomed enough to make a seal. I guess ill see by saturday, my header install is starting friday and will most likely take me saturday to.
Old Nov 23, 2006 | 10:25 AM
good luck on the install...im doin mine this winter/spring
Old Nov 23, 2006 | 10:33 AM
FuryZ28's Avatar
Like everyone one else says, get the brass ones- they won't melt. I did the same with my Edelbrock headers about 2 years ago and they're still holding strong...
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
95chwagon
Jan 13, 2015 09:19 PM
