What kind of sparkplugs are you using?
Old Nov 22, 2006 | 06:29 AM
Camarocracy's Avatar
What sparkplugs do you use in your car? I'm currently running NGK TR55's and have been pleased with them. When I do my header install, I want to switch plugs [even though the NGK's have about 2k on them at the moment]. I might upgrade to the NGK Iridiums, or just stick with the TR55's.
So what type of plugs are you running and how do you like them? And should I stick with the TR55 or upgrade to Iridiums?
Old Nov 22, 2006 | 11:36 AM
2000GTP's Avatar
I'm using the NGK TR-55s and have no complaints with them. Also, you can't beat the fact that they run around two bucks a plug. The Iridiums are more expensive, but will last longer. Other then that, you won't see any gains.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
Hal Fisher
Sep 30, 2015 09:03 PM
karpetcm
Sep 29, 2015 10:08 AM
