Old 11-21-2006, 02:53 PM   #1
krispy
Think fuel pump is out
Had to have the car towed back home from the store. It's been having problems recently. When I came out from the store and started the car it barely ran at 500rpms, touch of the throttle and it pretty much died. I can't hear the fuel pump working at all and there is only a little bit of air and some drips of fuel coming from schrader valve on the fuel rail after I tried to prime it about 5 times.
So time to punch a hole in the back hatch and put a new one in. I've read from previous threads that the racetronix pump works well, if I just get the 2nd one ($160) listed on the thunder racing page:
http://www.thunderracing.com/catalog...vid=4&pcid=166
Will be all I need?
Also, I know how/where to cut the panel, but are there any other guides on how to disassemble & replace the pump once I have access?
__________________
94 Black Z28 A4 3.23, Pacesetter LTs, Exhaust ala MagnaFlow, 17" Chrome Z06s, LT4 KM, Madz28 tune, tbypass
krispy is offline   Reply With Quote
Old 11-21-2006, 03:02 PM   #2
2000GTP
Premium Member
2000GTP's Avatar
Yeah, that should be all you need, it comes as a complete kit that has everything you need all the way down to the tube of lubricant and adhesive. The kit does come with instructions that outlines the process and here is a link that provides some additional info. about the pump:
http://www.racetronix.com/Racetronix..._Pump_Kit.html
__________________
1997 Camaro Z-28
A4,3.23s,T-tops,Black,Leather
Pacesetter LTs,catted ORY,Magnaflow CB,Spohn suspension, NX dual nozzle w/ Gen X2 upgrade,Mad Z28 tune,Mallory 685
2000GTP is offline   Reply With Quote
Old 11-21-2006, 11:52 PM   #3
krispy
thanks
__________________
Old 11-29-2006, 03:57 AM   #4
Racetronix
Racetronix's Avatar
Quote:
Originally Posted by krispy View Post
thanks
If you use the trap-door method there is a very good chance you will kill your new pump in short order. These FLT1 cars are getting old and most have a lot of sediment in the tank which will take out a Walbro pump quickly. Follow the factory procedure by dropping, inspecting and rinsing the tank before installing a new pump.
__________________
www.racetronix.com
Fuel Systems:
F-LT1, F99-02, F-98, Delphi & Siemens Injectors, 32#, 37#, 42#, 60#
Racetronix is offline   Reply With Quote
Old 12-08-2006, 12:35 PM   #5
Casey_SS
Good rule of thumb but my personal experience is leading me down a different path. Bought the full Racetronix kit last August, followed the instructions to a tee, dropped the tank out, cleaned it (not much sediment at all on my 97 @ ~120k miles), dried it in the sun, let the adhesive dry overnight, etc., etc.
Everything worked great until a couple of weeks ago when the pump started dying...can't get more than 18psi out of it at idle and drops to ~5-6psi with any throttle. Checked FPR, changed filter, etc. and just had to order a new pump yesterday.
Don't mind replacing a pump every now and then but if they're only gonna last a year and a half after cleaning the tank and following all the recommendations, I think I'll just go the trap-door method from here on out. Don't know how long others are lasting but I'll be damned if I'll tear half the car apart every time this happens. Cleaning the tank did absolutely nothing for the life of my pump...
__________________
30th Anniv. SS - HPDE / street car - 1LE suspension, Golen 396....lots of shiny stuff
Casey_SS is offline   Reply With Quote
Old 12-08-2006, 05:13 PM   #6
krispy
Right now its sitting with a full tank of fuel. Ill do the trap door method, siphon out the gas, then check to see how much sediment there is in there. Then I'll go from there.
__________________
Old 12-09-2006, 02:42 AM   #7
94Z28WP
94Z28WP's Avatar
I did the trap door method over a year and a half ago and I've had no problems.
__________________
...._
94 Z28 - A4 - HOOKER - '00 DASH SWAP - Z06's - etc...
94Z28WP is offline   Reply With Quote
Old 12-09-2006, 02:53 AM   #8
Klypto
Send a message via AIM to Klypto
i think thats whats going on with my car... i got it from the shop a few weeks ago, and they had to use an old tank... im "guessing" they cleaned it? i hope? but my new pump is acting up just like that sometimes! its driving me NUTS been in the shop for over a year long story + katrina, and i jUST got her back and shes giving me hell and it sounds like this is the exact problem.
ill start it and sometimes its 100% fine, but other times it doesnt strart at all, but if it DOES i have to play with it for 15 min sometimes.... and then will randomly kill as if out of gas short after (can be withing blocks)
sorry to hijack lol, but im going nuts, i thought it was bad connections but maybe its a bad pump?!
ps - is trap door method
thanks
cory
__________________
LS1 TR224-112, 12 bolt
Klypto is offline   Reply With Quote
Old 12-10-2006, 01:37 PM   #9
krispy
I precursor to it dying was piss poor performance. It started out just once in a while when I went WOT, then it happened often, then most of the time, and then all the time. For the past 6-10 months my car hasn't run nearly as well as it should have.
__________________
Old 12-10-2006, 02:15 PM   #10
byrons1502
i change a ton of pumps and don't clean the tanks(but they don't look that bad. but i don't like the trap door method either. if it is a quality pump it should not go out if you CHANGE YOUR FUEL FILTER ON TIME. 15,000 miles they are only $10. don't use cheap junk either. btw. racetronix kit is badas for performance cars
byrons1502 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
