11-19-2006, 11:43 PM
Summit universal x pipe
Well I'm about to get my motor back in my car. I am running pacesetter long tubes on it and I was wondering how much work there is putting together an x pipe set up on it with the mufflers dumped before the axel. Like will I have to bend anything or customize anything?
__________________
96 Camaro Z28, 355 LT1, Summit 58mm Throttle Body, CC306 cam, 1.6 S/A Rockers, Hardend push rods, Beehive 918 Springs, High flow oil pump, Accel Opti, Accel 30# Injectors, Accel afpr, Accel Coil, MadZ28 tune, T-tops, 6 Speed, Slp CIA, Pacesetter Long tubes, X-pipe, Dynomax Bullets.
11-20-2006, 07:44 AM
with a little tweaking it should bolt up pretty easily.
i used one for my duals setup...and LS1s are trickier than LT1s
__________________
ARREST-ME RED 99 Z-28, M6 - TSP Torquer V1 (233/233 .589" 112*), HS rockers, Flowtech LTs, 3" TDs, magnaflow 4x9s, FAST 90/90 ported, Mez EWP, 160 stat, SSRA, TSP lid, GMS maf ends, ASP pulley, Hurst w/LSS, Spec4, Fidanza FW, SS brake lines, BMR lca w/ brackets, phb, stb, 32/21mm swaybars, sfc, ZR1s
408.6 hp, 379.5 torque
11-20-2006, 11:41 PM
Sounds like that might be the way I want to go then. But I'm not exactly sure on 2 1/2'' or 3''. I have a 355 almost 11:1 compression lt1. cc306 cam in it. I'm thinking 3'' but not totaly sure.
__________________
11-21-2006, 07:38 AM
you won't lose much, if any by going with the 2.5" setup.
unless you plan to make more than 450rwhp...it should be sufficient.
__________________
11-21-2006, 04:23 PM
Brent, I am going to run 2.5" on my 383 once its done....it makes it so you can still lower your car. If you use 3", you ruin all chances of ever lowering your car, thus sticking you with the 4x4 look lol.
Jeff is helping me do all my stuff, and he said the summit x-pipe kit will work, but will require quite a bit of extra fabrication. I am using the flow-master merge kit for $161 from summit, he said when he did it on his 94 formula, he didnt have to cut anything, bend anything, or anything else like the summit kit that one of our other friends used did. He mentioned that the flowmaster is 70 more, but you will be happier with the sound, quality, and how much easier it is.
and if you decide the 2.5" isnt cutting it (like mine wont), install cutouts like I am doing
__________________
94 Camaro, built 4l60e, strange s60, cc503, mids, TNW plate kit
Quote:
Originally Posted by JasonD
Yo reamo04, that's a really nice t-shirt and Ima let people look at it, but our CamaroZ28.Com t-shirts are among the coolest of all time.
11-21-2006, 08:27 PM
My Summit 2.5 x-pipe kit with dynomax 12" mufflers and turn downs from Jegs. Didn't cut a thing for this kit to mate up to my JetHots. Welded in some O2 bungs for a wideband and extra think collector flanges. Love it.
JD
__________________
'94 Z28 Blk Vert. A4->M6, AS&M CAI, AS&M 54mm TB, CC503 XE 224/230 (.553/.561 lift w/ 1.65 RR's), LE Stage 3 Heads, 30lb SVO injectors, JetHot LTs, X-pipe Duals, Pro 5.0 Shifter/Short stick, Mccleod 7500rpm single disc w/ Ram Alum flywheel, 3.42 gears, LT4 Knock Module Install pictures _ Dyno Run
11-21-2006, 09:06 PM
Man that makes me want to do mine now. But i'm gonna do 3" and cut my y-pipe and mate theex-pipe kit to it. Mainly because i have Pacesetter and i have to worry about that support right after the drivers side header. Gonna make it with slip fit so if i need to re-install my catback it will be easy.
__________________
1998 Z28: 6.0L Iron Block, PRC 5.3L Stg2 Heads, G5x3 Cam, LS6 Intake, 36# Injectors, ASP Pulley, MTI Clear Lid, LT, TD X-Pipe, Dynomax Bullets, 3800 Stall
1993 T/A: 7PSI,GTP Stg.2 Heads, Ported Intake, GM847 Cam, 3500rpm Stall, etc, etc.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
