LS1 valve ajustment ???
Old Nov 19, 2006 | 06:36 PM
silver6speed's Avatar
new to the ls1 motor ! need to know if i can adjust my stock valves ?? in my 98 z28 .. to me it sounds like they need adjusting .
Old Nov 19, 2006 | 07:09 PM
SSpdDmon's Avatar
Valves can't be adjusted. The stock valvetrain is non-adjustable. The head holds the spring seat, the valve seal, the spring, the retainer and then the lock. Mount up the rockers with the pushrods in place, torque 'em down, and that's it. You can use shims and different length pushrods to make adjustments to valvetrain geometry or have a machine shop do some custom work on the heads. But for stock components, that shouldn't be necessary.
Old Nov 19, 2006 | 07:52 PM
Capn Pete's Avatar
He's probably referring to adjusting the rockers to get rid of that clattery "loose/sloppy rocker" noise? You know the one that every LS1 has ever since they're brand new???
Welcome to the LS1!! Great motors ... just a little too noisy from more places than just the exhaust?!!?
Old Nov 19, 2006 | 07:55 PM
johnny6's Avatar
Let me guess you still have the tap/knock? I gave up on mine, changed my pushrods, idler pulley, plugs, wires and i have no exhaust leaks i hope it blows up so i can get a new engine
Old Nov 19, 2006 | 08:09 PM
Capn Pete's Avatar
I've had mine since BRAND NEW, and it's had those "tap/rattle/knock/clatter" noises since DAY ONE . Now with over 105,000 km (~65k miles) and it still runs like a champ, I'm not too concerned about them any more .
Old Nov 19, 2006 | 08:13 PM
97z28/m6's Avatar
http://www.sdpc2000.com/catalog/120/...Cubic-Inch.htm
Old Nov 19, 2006 | 09:17 PM
johnny6's Avatar
A few more grand and i could get me a C5 Z06.
Old Nov 19, 2006 | 09:24 PM
Capn Pete's Avatar
Why don't YOU get one of those??? I'm not the one lacking power!!!
Old Nov 20, 2006 | 09:39 AM
Kraest's Avatar
Retired
Welcome to the LS1.
Enjoy the noise.
Old Nov 20, 2006 | 07:44 PM
thanks for the info !! got any suggestions ???
hey guys ,thanks for the 411 ,, i didnt think they were ajustable. guess its roller cam noise .. but then again my cars got 106,000 miles on it two . but other than that it runs like a new one , doesnt burn any oil has good oil pressure . best et with drag radials 8.34 1/8 mile 97.4 mph , spining out the hole . does anyone have some suguestions for my car ?? it already got the slp cold air kit , ported tb , polished maf ,free mods . 98 z28 m6 3.42 rear
Old Nov 20, 2006 | 07:58 PM
S. Holley's Avatar
Sounds like your car runs real STRONG 2 me.
Old Nov 20, 2006 | 08:23 PM
SSpdDmon's Avatar
Headers and catback are good for 30rwhp. If you want to save a couple hundred, a cutout instead of a catback is an alternative option.
Old Nov 20, 2006 | 08:34 PM
Kraest's Avatar
Retired
best et with drag radials 8.34 1/8 mile 97.4 mph , spining out the hole . it already got the slp cold air kit , ported tb , polished maf ,free mods . 98 z28 m6 3.42 rear
Unless you also have a power adder, your car doesn't go 97.4 mph in the 1/8.
Mike
Old Nov 21, 2006 | 09:10 AM
AL SS590 M6's Avatar
This must be a typo because I run low 7s in the 1/8 @ 96 mph
Old Nov 21, 2006 | 12:24 PM
Capn Pete's Avatar
Probably supposed to be 87.4??
