Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join nearly 80,000 enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
- Participate in over 40 different forums and search/browse from over 4 million posts.
- Communicate privately with other enthusiasts from around the world (PM).
- Post photos, respond to polls and access other special features
- Gain access to our free marketplace to buy, sell and trade cars, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support. |
11-19-2006, 06:32 PM
Car runs awful
This is a 1995 z28, built 383 with about 20,000 miles on it. At idle the rpms will bounce from 1000 to 1500 sometimes it gets lower and the motor just dies out. When it does this it'll take a while of cranking over until it fires up again and then throttle response sucks, i'll punch the gas and it'll stumble as it rises in rpm. While driving it'll stumble like this and looses power horribly. The car sat for maybe 3.5 months, could the gas have gone bad within that time and done damage to the fuel system? I also noticed a funny rotten egg smell and its not an exhaust without cats like smell, it's slightly different. Anybody have any thoughts on this? Thanks.
11-19-2006, 06:47 PM
Premium Member
Gas shouldn't go bad in 3.5 months. I'd drain the tank anyway and put in some fresh gas to rule it out as a cause.
__________________
Polo Green Metallic 97 Z28 M6
Arctic White 96 SS M6 (Should be here VERY soon.)
11-20-2006, 12:47 AM
Just noticed that if I unplug the MAF sensor, it does not stumble nearly as bad as it was with it pluged in.
11-26-2006, 12:19 AM
A couple of things come to mind from the problems you seem to be having,
1. Optispark
2. Fuel Injectors could be dirty/going bad
3. Fuel Pump going bad.
4. Check your fuel pressure, make sure it's around 43.5psi I believe
5. Check all plugs/wires to make sure they aren't fouled.
PS. Gas shouldn't go bad in 3 months, especially if it is 93+Octane Gas
-Dax
__________________
D. Adkins -
94 Red Z28 with black Stripes, K&N CAI, Ported MAF, Aluminum IE, Aluminum FlyWheel, New Spec Stage 2 Clutch, Cross Drilled & Slotted Rotors, Pro 5.0 Short Shifter, TB Coolant Bypass, Flowmaster Catback with Tips, Blackout Tail Lights.
11-26-2006, 12:29 AM
Does it sound like it is misfiring at all or just surging idle? Did the car sit in the open outside?
12-09-2006, 06:10 AM
Sounds like the problems I'm having with mine
__________________
Josh
1996 Red Z28 Vert A4-K&N CAI, TBB, Pacesetter LTs with ORY, Flow 80 muff, MSD wires, TR55s, Chrome Valve Covers
2005 Silver Pontiac Vibe-Wife's
2004 Blue Yamaha R1  -Micron Slips and other stuff.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
