flip up headlights question
Old Nov 18, 2006 | 11:18 AM
transAMdriv3r's Avatar
On my 94 ta, my passenger headlight goes down too far after use, is there anyway to limit how far it goes down?
Old Nov 19, 2006 | 09:48 AM
mmmchickenboy's Avatar
put the lights up then pull the fuses for the headlight motors (do this for safety; once the fuses are pulled you can turn off the headlights). then remove the headlight bezel and look around, you should be able to spot the headlight stops pretty easily. adjust the lower limit "up".
Old Nov 19, 2006 | 06:36 PM
thank you sir
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
