What are you running on your 305/350?
Old Nov 17, 2002 | 03:11 AM
oil pan 4's Avatar
I wanted to know what you were runing you your engine, who makes it, and what size shot?
What do you run on a 305?
What do you run on a 350?
I have a carbed Z with the stock intake manifold and edelbrook 750 vaccume secondary.
I'm not sure what the engine is, but it is fairly new.
The guy that sold it to me said he had a rebuilt 350 put in, its a new engine fresh paint all over with a new thin film of leaked oil on one side.
I had a mirror on a stick and a light, I could part of the block casting # (GM140- couldn't see any more) I need to move some wires and I'll be able see all of them.
I will get a head # soon too.
It has an older engine with out the 5.7 or 5.0 on the driver side.
Old Nov 19, 2002 | 08:04 PM
baddest305's Avatar
check this out you'll see what i run in my 305!!
http://mywebpages.comcast.net/craig0...kinmustang.avi
Old Nov 20, 2002 | 10:24 PM
AutoRoc's Avatar
dtrh
305 TPI converted to Holley 650 Vaccum Carb.
Nitrous Express LT1 Wet kit converted to use a Nitrous Express Stage 6 Carb. plate.
9 PSI fuel pressure for a "Safe/rich" mixture
150 shot jetting(Supposedly rear wheel numbers)
WITH ALL OF THE SAFETY ITEMS
Important! goodluck
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
