Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Predator Tuners for the 1999-2002 LS1 Camaro and Firebird On Sale!
Old Nov 13, 2006 | 11:53 PM
MarylandSpeed's Avatar
We are running a sale on DiabloSports Predator Tuner for the 1999-2002 LS1 powered Camaro and Firebird. We WILL NOT be undersold on these. Bring us a better price, and we will beat it (Just send us a PM, with a link, and a number to reach you at)!
These are in stock, and ready to ship!
Order Here for $369.95!
For a limited time, also get a FREE PC interface kit! This is essential for updating your tuner with the latest firmware for your tuner as it is released.
Keep in mind, we are an authorized dealer. Many of the vendors you see on the internet selling cheaper than this price are not authorized dealers. DiabloSport WILL NOT honor your warranty unless your receipt shows you purchased from an authorized vendor. That means if you have trouble with the tuner, or fry your PCM you are stuck and they will not help you!
View The FULL LINE of DiabloSport F-Body Tuners at the link below-
http://marylandspeed.com/index.php?cPath=49_201
*Price match offer cannot be included with free interface kit offer.
Product Details-
This tuner is an awesome addition to you 2005-06 LS2 Pontiac GTO. It comes with a DiabloSport performance tune, and also allows you to tweak other settings, and turn off anoyances such as the Skipshift feature in many manual GM vehicles.
This tuner is an awesome addition to your 1999-2002 LS1 Chevy Camaro and Pontiac Firebird. It comes with a DiabloSport performance tune, and also allows you to tweak other settings, and turn off anoyances such as the Skipshift feature in many manual GM vehicles.
Free Interface Kit!
For a limited time, get a free PC Interface kit with your Tuner (a $35 value!). This kit allows you to connect your Diablosport to your PC. Full Details can be found here!
What is the Diablosport Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
U7198 Stock Vehicle Tunes:
Performance Tune: Designed to add power and torque using premium fuel.
87 Octane Tune: (Trucks Only) Designed to add power and torque using low to mid grade fuel.
Factory Tune: Designed for users who wants to adjust parameters using the factory tune.
U7198 Specific Features:
Timing Table 1000-1800rpm (+/- 20%)
Timing Table 2000-4000rpm (+/- 20%)
Timing Table 4000-7000rpm (+/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Disable P0420 and P0430 codes
Adjust COT enable temperature
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
Enable/disable MPH, set high to disable
Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
Disable P-codes: 0410, 0412 and 0418
Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
All standard DiabloSport Predator features
Transmission functions do not apply to trucks with the Allison transmission.
Old Nov 24, 2006 | 02:45 PM
As a Thanksgiving special, you guys can use coupon code Z28TunerCoupon at checkout to save another $35 off this tuner.
This coupon is only good for two days, and the first two uses, so act quickly!
Old Nov 24, 2006 | 04:58 PM
2001NBMZ28's Avatar
Is the +500/-300 RPM for "in gear" A4 idle?
Old Dec 3, 2006 | 02:33 PM
Still Going!
ddr698
Jan 9, 2015 10:05 AM
Jazsun
Dec 29, 2014 12:14 PM
Dec 1, 2014 08:08 AM
tybz28
Aug 1, 2002 03:34 AM
