11-13-2006, 07:52 PM
what fuel injectors?
hey, i have a 94 z28 with all boltons. Headers, CAI, LT4 km, otvc plug wires, 373 rear, 160 thermostat, 1.6 crane rockers, lt4 valvesprings, and some suspension. I need some injectors. Should I get the svo 30lb, or is that too much, and would ls1 injectors be perfect for my combo? Thanks
__________________
94 Z28 A4 kn cold air intake, taylor otvc plug wires, pacesetter LTs, Ory, magnaflow catback, !AIR!, !cat!, !egr!, B&M tranny cooler, msd coil, strange 373, eaton posi, 160 thermostat,crane gold 1.6 rr, lt4 valve springs,lt4 KM,pcmforless.com tune
http://www.cardomain.com/ride/2489368
11-14-2006, 12:03 AM
LS1 injectors won't be any "bigger" at the lower stock fuel pressure of an LT1. Judging by your mods, you're fine with the stock injectors. But if you want to go bigger (in anticipation of future mods, H/C, etc.), something in the 32lb range is OK, and a logical step up that will work to over 400HP. SVO 30's (rated at 39psi fuel pressure) flow closer to 32's at the LT1's 43.5psi fuel pressure. Your PCM will need to be reprogrammed for the larger injectors, otherwise your car will run rich.
__________________
'97 Z28 Black T-top 6-spd - forged 383, CC XE224/230-112, ported heads, Crane Gold RR's, Comp 918's, Edelbrock headers & 52mmTB, 32lb Racetronix injectors, SLP CAI, Hurst shifter, McLeod ST, DMH cutout, AFS ZR1's with 17x11-315 rears, MT Street Radials at the track, UMI SFC's, LCA's, RLB's, TA, PCMForLess OBDI conversion & programming. 12.9@108 1.9 60' with major clutch issues.
'05 Blazer ZR2 4x4 - stock
11-14-2006, 07:23 AM
Premium Member
I would just stick with stock replacements. There are SVO injectors rated at 24# as well, it would then eliminate the need to have tuning done.
__________________
1997 Camaro Z-28
A4,3.23s,T-tops,Black,Leather
Pacesetter LTs,catted ORY,Magnaflow CB,Spohn suspension, NX dual nozzle w/ Gen X2 upgrade,Mad Z28 tune,Mallory 685
11-14-2006, 10:23 AM
What makes you think you need injectors?
If you do decide to replace them...30#s will give you room for future mods.
__________________
Jeff
95 Z28
A couple mods, nothing worth mentioning though
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
