Old 11-10-2006, 09:39 PM   #1
Gun5
Send a message via AIM to Gun5 Send a message via MSN to Gun5 Send a message via Yahoo to Gun5
Vented Gas Cap?
I was reading saw the 93-97's came with vented gas caps? I got a locking one months ago (so hating *******s wouldn't **** her up) does it need to vent or what? I know whenever I pull the gas cap off it releases pressure.. and my car always smells like gas (believe its the no Cats though?)
__________________
2000 Red Camaro Z28 M6 = Lid, Loudmouth, Soon to come H/C/I
1994 White Firebird Formula A4 = H/C + Full Bolt-ons - All but forgotten
Gun5 is offline   Reply With Quote
Old 11-10-2006, 10:08 PM   #2
razor02097
yes you need a vented gas cap. Not having a vent the depleting fuel will create a vacuum and the fuel pump needs to work harder to pump the fuel. Eventually the car will throw a code and or the fuel pump will fail.
__________________
Machine: stock 1994 Camaro Z28 LT1 T56
Current completed mods: !Skip shift, TB bypass, AIT relocation, TF elbow, K&N drop in filter, LS1 front brakes, B&M ripper, SLP line lock.
Best ET: 13.95 @ 99.97 MPH
Beat MPH: 14.07 @ 100.86 MPH
razor02097 is offline   Reply With Quote
Old 11-10-2006, 10:49 PM   #3
shoebox
shoebox's Avatar
Quote:
I'd say that was all wrong.
4th gens use non-vented caps. It's required for the EVAP system to work properly. There is a vent valve plumbed into the lines that vents the tank if a certain amount of pressure is exceeded.
shoebox is offline   Reply With Quote
Old 11-10-2006, 11:08 PM   #4
razor02097
How come my 94 Z has a vented cap then? There is a red valve inside the cap I know this cause I filled the tank over an hour ago
__________________
Old 11-10-2006, 11:51 PM   #5
shoebox
shoebox's Avatar
Can't tell you. They are supposed to be non-vented. Perhaps someone put the wrong cap on it. Lots of times you hear a hissing sound when you remove the cap when the tank is low. If the cap were vented, you would never hear this.
Old 11-11-2006, 12:04 AM   #6
razor02097
errr... well crap... I never hear hissing... how bad is it if the cap is vented? Every car I've owned had a vented cap so I thought nothing of it.
__________________
Old 11-11-2006, 12:30 AM   #7
shoebox
shoebox's Avatar
GM has had sealed systems for a long time. It probably is making the EVAP system ineffective, but apparently is not causing a SES because of it. Remember when computer controlled vehicles first came out and people would say tightening the gas cap might get rid of an SES light? That's because the system was being vented (by the loose cap) when it was supposed to be sealed.
Old 11-11-2006, 11:57 AM   #8
Injuneer
Super Moderator
Because someone switched your cap for a vented one. I bought my 94 new, and the cap was, and still is 12+ years later the correct unvented one. There is a pressure control valve in the EVAP system that corrects for vacuum and pressure in the tank. OBD-I cars can get away without the unvented cap. Put a vented cap on an OBD-II car and it sets a code and turns on the SES light. Emissions inspections will test the cap to insure it will not leak under pressure.
__________________
Fred
94 Formula A3+1: 381/TH400+OD/N2O 11.1 @ 128 on a 125-shot
Detailed Mod's List - - - - Step into my office.... - - - - Trailer Queen......
Injuneer is offline   Reply With Quote
Old 11-11-2006, 12:44 PM   #9
Gord's Green Z28
Quote:
How do they do that test?
Gord's Green Z28 is offline   Reply With Quote
Old 11-11-2006, 02:51 PM   #10
razor02097
Quote:
they have a machine that they screw the cap into... wierd thing is my gas cap passed...
__________________
Old 11-12-2006, 02:05 AM   #11
Gun5
hmm so my hissing noise is normal just letting the pressure go
__________________
Old 11-12-2006, 08:44 AM   #12
shoebox
shoebox's Avatar
Yes, hissing is normal.
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
