Can i put a th400 from a 1990 chevy truck in my car???
What do i do about the speedo... It has the correct speedo hook up, but will it work? What all is needed? M-6 mount and a spohn torque arm++++++what else? I have a couple of other th350s and 400s but they have a mechanical speedo...
You'll need a driveshaft slip yoke for a TH400 since the yoke is larger for a TH400 than all the other GM trannys you're old yoke won't work. The output shaft is a larger diameter. Most truck yokes are a bolt on style and that won't work. The driveshaft will then need to be shortened or a new one made.
TH400 don't use detent or TV cables to downshift. It's done electrically so a switch needs to be installed on the throttle somewhere.
The speedo should work but it may need to be recalibrated for the small f-body tires. F-body is usually 26" tall and trucks are usually 28" tall. The rear end gearing will also throw off the calibration.
Since the computer needs to know what speed you're going, if it isn't calibrated properly the car may not run right.
Originally posted by graham
The TH400 was available in 1990 Chevy trucks??
As far as fitting it in an F-body...make sure that the larger drain pan doesn't sit too close to the ground. The trucks had a larger pan than passenger cars.
The 1990 454SS has the TH400 with 3.73 gears. My 91 454SS has the 4L80E and 4.10 gears. It's nice to have the OD with the 4.10 gears but I'd still rather it had 3.73 gears. I still get around 15-17 mpg on the highway even pulling a trailer.
I grabbed a few parts off a 1990 TH400 that was in a 3/4 ton GMC van. It had the electronic speedo drive so that part wasn't just offered in the 454SS trucks.
I have a 400 in my 96. The swap is cake. Pix on my web site. Mine is full manual with t-brake.
LJ
para.noid.org/~lj
Acceleronics.com
LJ
para.noid.org/~lj
Acceleronics.com
NewsBot
Dec 3, 2014 12:30 PM
