11-05-2006, 10:44 PM
headers????
I want to get some long tube headers in the very near future, but i am not sure what brand i want to get. i have been set on hooker super comps for a while, but other companies like pacesetters use a thicker gauge steel tubing. anyone have either brand, and can you tell me what you think about the header???? also i know the whole concept of ceremic coated headers keeping the heat in the tubing which makes exhaust gases flow better. he is my last question, is it really worth getting headers coated????
__________________
2000 Z28 M6
SLP Loudmouth, Pro 5.0, Volant CAI
UMI - STB, LCAs, LCA Relocation Backet, Triangular SFCs, TB mounted TA, Panhard Bar, Moser 9" 4.11s
11-06-2006, 07:52 AM
"is it really worth getting headers coated????"
ABSOLUTELY
not only does it theoretically increase exhaust gas flow, but it also keeps engine bay temps donw, reducing chances of melted wires.
not to mention it looks sexier
__________________
ARREST-ME RED 99 Z-28, M6 - TSP Torquer V1 (233/233 .589" 112*), HS rockers, Flowtech LTs, 3" TDs, magnaflow 4x9s, FAST 90/90 ported, Mez EWP, 160 stat, SSRA, TSP lid, GMS maf ends, ASP pulley, Hurst w/LSS, Spec4, Fidanza FW, SS brake lines, BMR lca w/ brackets, phb, stb, 32/21mm swaybars, sfc, ZR1s
408.6 hp, 379.5 torque
11-06-2006, 06:53 PM
My Kooks LT's are ceramic coated with a 2000º ceramic coating, my headers never get hotter than 145º. That really helps with the underhood temps.
11-06-2006, 06:56 PM
If you do a lot of driving in all kinds of weather, get stainless headers. If it's a weekend-only, sunny-day driver...get coated Pacesetters.
11-06-2006, 07:02 PM
Stear clear of SLP's. Not the best as far as power gain, the clearance is...... ok....... with stock rideheight, but once you lower the car, it REALLY gets bad.. The y-pipe is most of the problem. -I had to be the first one w/ first hand complaints...
Go with the thicker tubing, it'll help as far as noise. Teke has the flowtech's and they seem to tuck up there pretty good. I heard Pacesetters were pretty good. Price, finish and fittment...
Coating is a good idea. It protects the finish and the welds. -as far as rust.
__________________
2000 Z28 M6 ......H/C/I, susp, exh -LOTS More!-
1995 Ford F150 Extended Cab, spray on bed liner, 5.0L V8
2006 Yamaha YFZ450 !Lid, !SA, Stainless oil filter, jetting, Cam mod , AC Nerfs, HMF Full pipe, Graphics..
Listen to the CamaroZ28.com Podcast!!
11-06-2006, 07:51 PM
Pacesetter Ceramic Coating
11-06-2006, 08:00 PM
11-06-2006, 08:30 PM
I made good power with my SLPs headers...
....would I buy them again....not a chance in hell
Kooks or FLPs
__________________
07 TBSS 3SS 357rwhp/374rwtq
00.5 RSV Millie..140hp and 335lbs
99 LS1 SS #133 466rwhp/540rwtq 11.61@124mph
94 LT1 Z28 355ci ATI p600b FMIC chiller,N2O..F1?
86 C10 ....hopeless
11-06-2006, 09:01 PM
ive had hooker super comp lts on my car for awhile, ceramic coated, no problems with clearance, hooker y pipe sits snug against undercarriage, plenty of room for lowering car
__________________
99 Z28 a4.
Fra, Lid, Maf, Tb, Lt's, Custom TD's w/ Dumps, Sfc's, Lca's, Ta Girdle, Dbl Adj Phb, Eibachs, !Cat, !Egr, !Air, !Wires. Appearance mods, In The 12's
Intake Manifold Painting by kwiksilverz28 http://www.camaroz28.com/forums/member.php?u=15294
11-06-2006, 09:06 PM
Kooks or FLPs
Not trying to jak...
What #'s you get from yours?? What mods?
__________________
11-06-2006, 09:15 PM
Quote:
MTI lid
!EGR
Jet PCM ----dont know if that really did much
SLP LT no cats
cut out
344rwhp
air/fuel was 12.7:1 from 2200rpm up
__________________
86 C10 ....hopeless
11-12-2006, 03:19 PM
Why hasn't anyone mentioned QTP? AWESOME design, stainless (put together VERY nicely), and a VERY easy install. I know the headers weren't the ONLY thing, but they are part of my combo that netted my 11.75 run with bolt-ons only. I noticed a HUGE difference after I installed then (and I'm still un-tuned) QTP's are teh win
__________________
1999 Trans Am A4 (11.75 @ 115 w/ 1.57 60' ---- Stock Internals)
2008 Buell 1125R
11-12-2006, 05:03 PM
Quote:
Maybe because in the past you could buy a set of ported heads for what those headers cost? Now that they have them for $725 thats much better (almost half of the original cost) but you can still buy a set of headers and ORY for ~$500 and use the extra $200 on something else. If you're on a budget $200 can be a lot.
Its like dynatech, great header but $1500???
__________________
00 SS M6 - Not so stock, but still too stock.
08 Trailblazer SS - Just a stock SUV
11-12-2006, 07:41 PM
Quote:
Same here, The pro kit is just counting days till it goes on.
__________________
--Jason--
2002 Z28 M6... LSxNATION
"One day your life will flash before your eyes, make sure it's worth watching."
RIP Scott, Ill see you when I get there.
11-12-2006, 08:45 PM
We install alot of pacesetter coated LT's and Jet-Hot LT's... What is your budget like? As said above QTP and Kooks are awesome headers but have a higher price tag. Where as Pacesetter and Jet-Hot are a couple hundred cheaper.. Check out our site at www.CustomSSI.com for prices and if you have any questions feel free to contact us..
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
