Custom 1992 GMC - Supercharged LT1
Old Oct 30, 2006 | 02:28 PM
wallacehat's Avatar
Make an offer - Custom 1992 GMC - Vortech T-Trim 383 LT1 - 500hp+
I am willing to make a deal on this truck, it must go by December 1, please make me an offer...
Exterior
Custom Metallic Red to Metallic Light Maroon Paint
Custom Billet Grill
Custom Front Bumper from Turbo Diesel, with Bumper Strip cut/finished to match
Snugtop bed cover, custom painted at the same time
Rhino Lining sprayed-in bedliner, custom painted to match
Chrome sport mirrors
Custom tint with transferable lifetime warranty
New sliding back glass, tinted
Wheels/Tires
17x10 Centerline 5 Star Polished billet aluminum wheels (x4)
Weld 15x10 rims with 23.5x10.5 ET Drags ˝ tread left (These come free with the truck)
Nitto 450 275/50-17’s on the front – less than 2000 miles
M&H 325/45-17 Drag Radials on the back – less than 2000 miles
Suspension
Custom 4-link rear end setup with ladder bars and coilovers
Bilstein racing shocks all the way around (adjustable in the rear)
2” drop shackles in front (stance is even front to rear)
All bushings, seals, bump stops, and wearable parts were replaced during buildup in 99/00
Racing Prepped Turbo 400 transmission with “switch pitch” (can be activated via switch or via brake pedal)
Gear Vendors Electronic Overdrive unit
2000rpm low stall/3000rpm high stall converter from Phoenix Transmission
Brand new Heavy-Duty Auburn Posi Unit
3:42 rear end gear ratio
Interior
Custom leather seats (feel like butter – literally the softest seats I have ever felt in my life)
Light Oak wood trim throughout
Custom Mounted Radar Detector in overhead console – no unsightly wires
Kenwood cd-receiver with flip face
Planet Audio 5-channel amplifier
Kenwood 4x6” coaxials in the stock dash location
Kenwood 4” component set in custom kickpanel enclosures
Kenwood 4x10” coaxials in stock rear location
Dual Orion 8” subwoofers in custom, interior matched enclosure behind passenger seat
Power Windows, Power Door Locks
Very Cold AC
Dakota Digital gauge package, replaced factory gauges
Keyless entry and alarm system from CodeAlarm
Interior was stripped out and lined with double foil insulation and new plush carpet
Surprisingly quiet on the freeway
Engine
Fully racing built 1996 LT1 by John Simms at Bobby Shahan Race Cars in Cabot, AR
Just finished in July/August this year (2006) and currently has 1400 miles on it
1996 LT1 Block
Vortech T-Trim Supercharger, custom oil feed with separate oil filter
8.3:1 compression
Custom JE Forged Pistons, molybdenum SWAIN coated
Childs and Albert 5/64ths Gapless Piston Rings
Air Flow Research AFR 190 heads
Cometic Head Gaskets
Ported and polished intake
52mm Throttle Body, with airfoil, ported and polished
Pro Mod 6” Rods
H-11 1.500 Springs
Titanium valve spring retainers
Manley ProFlow valves, 2.02 intake, 1.6 exhaust
Roller Rockers
.080 Pushrods
Camshaft – 218/224 roller with 112 separation and .560 lift
8 rib custom serpentine belt drive
Custom mounted Spearco air-to-air intercooler
MSD Pro Billet Optispark Unit
Mezeire Electric Water Pump
Crane Fireball Coil
MSD 6BTM Ignition
46lb/hr Lucas Injectors
Custom Programmed 1993 PCM – uses MAP (Speed Density)
All Aluminum Racing Radiator with dual electric fans (one pusher, one puller)
Hooker competition series long tube headers
Full 3” true dual exhaust, no cats, dual Borla XR1 racing mufflers
Mobile 1 synthetic is the only thing it gets.
Make mw an offer $$$$
Here are the only known issues with the truck:
#1 – It can make more power with more fuel – Two options:
1 - Standalone Engine Management
2 - Acceleronics (www.acceleronics.com) Fuel Injector controller and
85lb/hr injectors
It is tuned to run on the current setup. It is tuned conservatively, for every day driving and longevity. If you want absolute max power and torque, it will need more fuel. Solution 1 is difficult and expensive, but very capable, Solution 2 is less expensive and will get the job done.
#2 – The drivers side power door lock is worn out, needs to be replaced
#3 – You will probably want to plan on getting a new set of Nittos for the rear, the drag radials DO NOT like it when it is just a little bit wet. They are useless unless you like to only drive when the weather is perfect. If it sells for $20,000, I will include a new pair of Nitto 450’s, mounted and balanced!
#4 – The backlight on the Kenwood receiver stopped working recently, but the unit still plays and works just like it always has, without a display, not sure what it will cost to fix, but it may be time for a head unit upgrade anyway. If it sells for $20,000, I will purchase and install a new head unit for the buyer up to $350.
#5 – The fuel gauge works, but you have to press in on the dash to see it, it is the only gauge in the cluster that acts funny. Dakota Digital says that if I remove the unit, send it to them, with a check for $20, they will repair and ship it back. I do not have the time to mess with this, so I will leave it up to the new owner.
#6 – There is a slow leak in the AC. A single charge will last all summer, but it will have to be charged up the next year. It is an R134a system, so anyone can do it. The unit is currently charged and blowing cold, although it wil not be needed throughout this winter.
The paint is in near-perfect condition, and it is a VERY beautiful color. There are just a couple of slight nicks that I plan to have fixed by the man who painted it before the buyer picks it up.
The truck runs and drives perfectly. It will scream if you get into it and it will make the hairs on the back of your neck stand up. This truck is fast and is not for the novice driver. It is in excellent condition and has been the object of a lot of tension in my home for the last several years. Year one, it only went to car shows, year two, I took it out more to play, and to the track a few times, year three it served as a backup/daily/fun vehicle – this is the year I had a couple of piston ringlands collapse – hence the recent buildup. It took almost 12 months to get her done, and a lot has changed in my life. I started a business – HomeTroniX www.myhometronix.com – and I am now ready to take it to the next level. I made an agreement with the wife that in order to purchase a new Dodge Sprinter Cargo van for the business, this truck must go.
The price is very reasonable. You could not build the motor and transmission for the price that I am asking, so basically you are buying a racing motor and transmission and getting one of the cleanest 1992 trucks to go with it.
Please feel free to contact me if you have any questions at 501-920-1487 and I will be happy to arrange a test ride or provide further information. You may also email me at wh1513@swbell.net.
Pics:
Last edited by wallacehat; Nov 6, 2006 at 03:53 PM. Reason: Decided to accept offers...
Old Oct 30, 2006 | 09:50 PM
wallacehat's Avatar
More Pics:
Old Oct 30, 2006 | 09:51 PM
wallacehat's Avatar
last one:
Old Nov 6, 2006 | 03:49 PM
wallacehat's Avatar
Looking for offers. This truck must go by December 1. I will consider any offer on this truck.
Thanks!
Wallace
501-920-1487
cyteone
Feb 7, 2015 06:04 PM
CARiD
Jan 27, 2015 06:27 AM
CARiD
Jan 14, 2015 04:00 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
tubby
Oct 13, 2003 09:16 AM
