Old 10-30-2006, 01:05 AM   #1
Schurters LT1
Fuel system help
Hey guy's
Looking to up the fuel system this winter....need some help
-who can weld the fitting on the back of your fuel rails
-what kind of line should i run from the tank to the front
-what parts do people rec of this kinda set up
-where should the FPG go ?
thanks
__________________
Harshaw Racing Engines 355, Accel DFI Gen 7 ,Vortech T-Trim' custom 4" intake pipe, Bret B Custom blower cam, Alky control kit, Larger FMIC,
The lil ole LT1 just put down 686rwhp and 590rwtq!
http://videos.streetfire.net/video/9...2200b23723.htm
http://client.webshots.com/user/jschurter
Schurters LT1 is offline   Reply With Quote
Old 10-30-2006, 07:40 AM   #2
RealQuick
Supporting Vendor
Jeremy, I bought a setup used, but it consists of dual walbros, 8AN feed that y's into the back of each rail and a single 6an feed out to the regulator and 6an back to the tank. This guys does fuel rails I think:
http://lt1intake.com/services.htm
Shoot him an email.
Jon
__________________
96 TA WS6... 383ci + T76 =
95Z M6 - heads/cam... 383rwhp/353rwtq sold
www.lt1boost.net ... your home for turbo hotparts
RealQuick is offline   Reply With Quote
Old 10-30-2006, 08:51 AM   #3
CALL911
Premium Member
I have been told my fuel system will safely support over 800 RWHP. I have a dual Walboro in tank system, ran to a HOBBS switch to kick the 2nd pump on when I reach 4#'s of boost. All ran through the stock fuel lines.
Also, my fuel pressure gage is mounted on my A-pilar, under my boost gage.
__________________
98 Formula WS6 M6, heads, cam, intake, bolt ons, 441 RWHP
95 Z-28 M6, 383, D1SC, FMIC, 614 RWHP on pump gas with the stock PCM
CALL911 is offline   Reply With Quote
Old 10-30-2006, 02:26 PM   #4
ZBLKHELLRZR
Thumbs up
Just like Call911 dual intank walbros hobb switch but I'm running parallel braoded -8 feeds and -6 return. Ran my regulator (Fuel lab) on top for easier access.
ZBLKHELLRZR is offline   Reply With Quote
Old 10-30-2006, 03:29 PM   #5
97WS6Pilot
97WS6Pilot's Avatar
There are some cars out there making 1000HP on stock fuel lines and dual walbro. But if you wish to do it, here is my opinion.
I would use steel or aluminum tubing anywhere it does not need to flex. Hard tubing on the bottom of the car will provide excellent fuel cooling.
The best looking setups I've seen are the ones where the installer knew how and where to bend the hard lines. 1/2 inch lines for feed. 3/8 inch lines for return should be sufficient.
Autometer makes an electric fuel pressure gauge so you don't have to run fuel pressure lines inside the cockpit.
__________________
97 WS6 TA, Rebuilt 355, 15psi Procharger F1A. Sold http://www.cardomain.com/ride/2373730/1
93 Turbo Corvette, Polo Green, Accel DFI Gen 7, Stock internals, Roller rockers, 218/230 Cam, Meziere EWP
97WS6Pilot is offline   Reply With Quote
Old 10-30-2006, 05:32 PM   #6
Schurters LT1
i thought the max for the stock lines were 700ish rwhp........
i have the dual in take set up from lonnie....
if i don't have to change and stay stock i would be ok..with that .......
__________________
Old 10-30-2006, 05:39 PM   #7
Schurters LT1
Shoot him an email.
Jon
Jon,
Do you have any pics of your set up ????
if so just send them to my email...thanks
__________________
Old 10-30-2006, 05:48 PM   #8
T/A KID
60lb mototron injectors
Racetronix 255 intake Fuel pump kit with plug and play with BAP
KB Boost-A-Pump
Stock lines (only running 6an to clean up the driverside of the engine bay) and Stock FPR in stock location (may upgrade that since the stock one has 130,000 milesbut it will be with a stock style)
Rich on here made 713RWHP with basically the same setup mentioned before (I think he had 70 lb injectors) Stock lines are good for about 1000 horse from what I have seen.
I have also witnessed guys make close to 750RWHP with my fuel system mentioned above.
Dual intakes are Nice, and are Future mod Friendly but most time not needed.
__________________
http://s69.photobucket.com/albums/i77/TAKID/?start=0
VRE 383, D1SC Procharger, AFR LT4 heads/Custom Super Vic, Paddle shifted 4L80E/PY3600, Midwest Fabed 9, EFI LSX pcm, 02 WS6 Front clip, Plus too much other crap to list.
Goal is a 9 second Daily Driver
T/A KID is offline   Reply With Quote
Old 10-31-2006, 08:11 AM   #9
RealQuick
Supporting Vendor
Quote:
Originally Posted by Schurters LT1 View Post
Jon,
Jeremy, let me see what I can find. I think your fine with your current system, and unless you see a drop in fuel pressure or A/F leaning out then I wouldnt worry about it.
__________________
Old 10-31-2006, 11:05 AM   #10
Roadie
this is a pic I took of my setup when I mocked it up on a spare intake:
everything here is tapped and threaded instead of welded... -8an is 3/4-16 and -6an is 9/16-18. Use bottoming taps and tighten them up good and they seal very well.
I used o-ring to flare style fittings on the back since they are shorter. And I cut the flare portion off one side of each of the 90* ends that I used at the front to gain more thread bite.
I mounted the regulator as far forward as possible since I have an LS1-style hotchkis STB on the car. If I had a BMR or other, I'd have mounted the regulator at the back or somewhere else.
I also have a set of rails with -8an fittings welded to the back that I'm not using. It just doesn't have anything done to them for return yet.
a few other pics:
Roadie is offline   Reply With Quote
Old 10-31-2006, 12:55 PM   #11
xxsaint69x
Premium Member
xxsaint69x's Avatar
Send a message via AIM to xxsaint69x
i think unless u planning on making over 800rwhp, stock lines will be just fine
__________________
700+rwhp 15+psi 95' Z28 M6
ATI D1 * AFR 227s * Big Bump Stick
Moser 12-bolt (3.73) * McLeod Street Twin
Baer Track Kit
* Fikse FM/5 * GMMG
xxsaint69x is offline   Reply With Quote
Old 11-02-2006, 10:39 AM   #12
RealQuick
Supporting Vendor
a few other pics:
Nice Jered!
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Forums Directory
