New times but, E.T.-M.P.H. off, what do you guys think?
Best before: 6.85@101.xx, 1.50 60ft., this is leaving with the juice on (trottle switch), 38 deg total timing
Best now: 6.81@104.45, 1.58 60ft., this is leaving on the motor and hitting it when I felt it hook, and 32 deg total timing
I went up +75hp on the juice
1.58 is a good MOTOR 60ft ,which is probibly where I hit it, and in testing this motor wont fall out of a tree with less than 36-40 deg total timing, I took out 6 deg because of the extra juice but with 112 oct. I think I can bump it back up to 38deg. On the motor with the timing at 38 deg it pulls all the way, but at 32 deg it seems to lag, when it ran 6.81 it also lagged w/32 deg.
Also I am going to try it off the line. I have a friend whos dads Demon runs 6.20's at 103-104. With the timing and leaving with the juice on do you think I can run at least 6.50's?
Thanks guys ANY help is appreciated.
