42lb SVO injectors good enough?
Old Oct 3, 2006 | 07:09 AM
flusz28's Avatar
i plan to run 10 psi and wanted to know if i have to ditch my 42's for something bigger? i was pushing 8psi with 42's,single walbro and stock FPR and no problems. i'm not using a Fuel managment system for the blower either.
Old Oct 3, 2006 | 10:13 AM
97WS6Pilot's Avatar
Re: 42lb SVO injectors good enough?
I can't tell if you have ported heads or not by your signature. If you do you will be close to maxing the 42 lb injectors at 12psi.
Old Oct 3, 2006 | 10:30 AM
flusz28's Avatar
i think i will stick with 10psi for now and later on add more... so for 10psi would i be good?
Old Oct 3, 2006 | 09:33 PM
SVTNTMR's Avatar
Im LS1 but making 570rwhp with 42# SVO's and 10# through an auto.
Old Oct 4, 2006 | 07:37 AM
flusz28's Avatar
do you have two fuel pumps or a fuel pressure regulator?
Old Oct 4, 2006 | 11:24 AM
97WS6SCharged's Avatar
Order a set of 60s from Racetronix.
Old Oct 4, 2006 | 11:45 AM
flusz28's Avatar
Eric from Victory racing said i would be fine with the fuel pump,42's. but to just add a FPR.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
