ASR Traction Control or not?
Old Sep 28, 2006 | 07:58 AM
brink's Avatar
I have this installed on my car.. and I've been using it for daily driving..
When I go to the track I've been hearing I should turn it off.. What are the uses of this?
Also, when i turn it off, what differences will I see? Will the car go faster or just spin the tires more?
Thanks.
Old Sep 28, 2006 | 08:33 AM
SSpdDmon's Avatar
Re: ASR Traction Control or not?
See page 4-9 in you user manual...
https://www.mygmlink.com/pdf/go2cont...2001camaro.pdf
ASR = Acceleration Slip Regulation
Any time you're racing the car, you always have to understand the limits of the tires. Their friction coefficient is what determines the point where you have the most grip. This is usually at the point where the tires have just started to spin and are on the edge of breaking loose. To get the best time, you need to apply the most power from the engine without going past this point with the tires. The stickier the tires (ie drag radials), the more power you can effectively "put to the ground." Traction control systems like the one we have installed from the factory limit the power by applying brakes, pushing back on the gas pedal and retarding spark to stop wheel spin. So ideally, a good driver can always put down a better time with the ASR off as this is a bit overkill. However, there are some aftermarket traction control systems that monitor wheel spin and control it with spark only. They are quite a bit different and can actually work fast enough to keep the tires at the point of max grip to give you the best acceleration possible in all conditions (wet or dry). Unfortunately, we're not lucky enough to have that kind of sophistication in our traction control system.
Old Sep 28, 2006 | 10:18 AM
AL SS590 M6's Avatar
Thanks.
Turn it off at the track to get the best ET. But you will have to "drive" the car. You'll have to modulate the gas at launch to push it as hard as the tires will take without wheel spin. Don't go out there and stomp the pedal and do a half track burnout netting a 16 second time slip. And yes I've seen this many times.
Old Sep 28, 2006 | 10:32 AM
brink's Avatar
I see, well I'm going to midnight madness tomorrow to mess around a bit.. First few times I go down will be just seeing what my tires can do..
Hopefully by the end of the night i can pull into the low 13s.
Old Sep 28, 2006 | 08:11 PM
skifast87's Avatar
yeah i turn in to a scary person when i press that lil switch. Im working on getting one of them there new fangled driver mods.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
