how much would you spray on my setup?
Old Sep 24, 2006 | 06:05 PM
blackztpi's Avatar
Hate to ask the every day question, but i'm just wondering what everyone else would feel comfortable with in my situation. mods in sig. i have .004" piston to wall clearance and stockish ring end gaps. i filed all the rings to within stock specifications listed for lt1's. I'm probably only going to do 50-75 on the streets just to have fun, but i'm wondering if i can run 150 shots RELIABLY. i know stock will hold 250 shots, but only so many.
all shots will be done on fp safety switch and with a nitrous management unit.
Old Sep 25, 2006 | 09:12 AM
jldak318's Avatar
Re: how much would you spray on my setup?
stock....250..... thats not good. you will prob be safe and reliable with a 125-150, it all depends on the tune on a stock car.
on your car seeing that you have the forge rotating assembly, you can spray 200 on your pistons safely with the proper tune and saftey precautions. but i would say 200 on your setup for sure.
Old Sep 25, 2006 | 01:32 PM
Moshbmx1's Avatar
Stock 250....no, maybe 150 with a good tune and such. You can spray 150 comfortably on your set-up
Old Sep 25, 2006 | 03:10 PM
blackztpi's Avatar
oops, sorry guys. i meant 150 on a stock motor. i won't spray over 150 on mine
Old Sep 25, 2006 | 03:56 PM
Moshbmx1's Avatar
Thats more like it. Also look into a window switch and colder plugs if you dont already have them
Old Sep 25, 2006 | 07:01 PM
ghost stripes's Avatar
my stock motor with cat back exhaust and a k&n filter run 150 shot all day no problem
Old Sep 26, 2006 | 10:15 PM
blackztpi's Avatar
ghost...a friend of mine used to do that.... lets just say after 6 months his 5w-30 decorated the highway.
Old Sep 27, 2006 | 06:34 AM
andy katzelis's Avatar
With a conservative tune you can run 150 all day long. I'm spraying 150+ on a 130K miler. The computer will protect you from youself, unless it's not stock.
Jeff1904
Jun 5, 2016 05:00 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
damnyankee36
Sep 9, 2015 07:06 PM
