South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Speaker HELP!!
Old Nov 13, 2002 | 08:47 PM
S. Holley's Avatar
Speaker HELP!!
I need 2 front door speakers...I blew mine. I 'll take the factory ones.
Also...do you have to take off the door panel to replace them...
thanks
Old Nov 13, 2002 | 08:54 PM
john storie's Avatar
i ain't got none, but I can answer some Q's for ya.
they are the 6 1/2 'oversize' as crutchfield calls them, and you can put a regular 6 1/2 in there by using the screws on only one side, and letting the other side swing, or run a peice of strap out to it somehow
6 3/4 will fit, or the Pioneer 6 1/2 with the goofy multi-fit ring.
the grilles are stuck to the door panels with some really mungy thick monkey snot stuff. you can push the edge of the grill in towards the center, and take it off, and you can wiggle the speaker out. it's a PITA and you usually mangle the speaker somehow, the door hole is like lower than the speaker hole
plus, i don't think you have room to finagle a regular 6 1/2 onto the odd sized mount through the grill hole.
not much encouragement, huh?
Old Nov 14, 2002 | 06:22 AM
Kwiksilverz28's Avatar
Use the right size speaker, and pull the door panel. The whole thing will take less than an hour a side. If you blew the speaker because you listen to the radio loud, upgrade. You can get a decent set for $100.
Let me know if you need help. I am busy lately, but I can probably give you a hand some evening!
Old Nov 14, 2002 | 07:01 AM
bad86z28's Avatar
I have one speaker out of my friend's wrecked '94. I believe its a Boston Acoustic. Not sure of the size, but I'll check.
Did you get that interior in? I'm pretty sure I gave you everything, but just let me know if you're missing a piece and I'll try to find you one.
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
Bxlt1
Sep 10, 2015 08:16 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
