How to get the car to relearn idle after cat removal?
Old Sep 16, 2006 | 10:04 PM
convertz's Avatar
My cat had been rattling for a little while, so I ordered a new one, but before it got here I decided to hollow out the old one. I put it back on the car and started it, idled fine, maybe a little rougher, but nothing bad.
Went for a drive, and a few minutes in it felt like the car had a missfire, sitting at a light the idle would drop down real low and bounce around a bit, wouldnt pull hard either.
Turn the car off, went into a store, come back 1/2 hour later, same deal, starts fine few minutes later feels like it has a missfire.
The car has RK-Sport headers and a hooker muffler, the cat had ~105,000 miles on it. Is it possible that it was so clogged that the car is having trouble running without it?
I hear you can disconnect the battery cable to get the computer to "forget" everything it had stored in the idle table, but how long does this have to be?
Just a coincidence and I have a missfire somehow also?
thanks
sorry its kinda long
-Ted
Old Sep 16, 2006 | 10:09 PM
razor02097's Avatar
Re: How to get the car to relearn idle after cat removal?
30 minutes but overnight to be safe. Disconnect the negative terminal of course
Old Sep 16, 2006 | 10:33 PM
shoebox's Avatar
Pull the PCM BAT fuse for about 15 seconds to reset the PCM.
The more you idle/drive it, the faster it will learn.
Old Sep 17, 2006 | 01:29 AM
Bayer-Z28's Avatar
THe OBD II computers learn faster than the OBD I's. -From what I'm told.
And yes, 15 second disconnect for that. I was tought 5, but 15 isn't a big differance...
Old Sep 17, 2006 | 08:01 AM
shoebox's Avatar
15 give a margin of error for those that cannot measure time well.
Old Sep 17, 2006 | 03:00 PM
convertz's Avatar
Thanks for the confidence,
bfmv13trivium
Jan 14, 2015 09:57 AM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
Dec 1, 2014 08:08 AM
USAirman93
Nov 24, 2014 03:37 PM
