One of my headlights isnt coming up
Old Sep 15, 2006 | 12:46 PM
Lt1 and Ls1's Avatar
So what all do I need to check to see what the problem is. I cant even lift it up when the lights are on
Old Sep 15, 2006 | 02:12 PM
moparman's Avatar
Re: One of my headlights isnt coming up
Have you tried the manual way by turning the device that will raise and lower the lights? Sometimes I have to manually raise one on my car, and that seems to fix it for awhile.
Old Sep 15, 2006 | 02:57 PM
I will try it thank you. Not to sound like an idiot but can you tell me how
Old Sep 15, 2006 | 06:30 PM
moparman's Avatar
Raise the hood and locate the headlight motors. There is one beside each headlight bucket. They probably have a rubber cap on them. Remove the rubber cap and see if you can turn the motor by hand to raise the headlight.
Old Sep 15, 2006 | 06:46 PM
Okies thanks
Old Sep 16, 2006 | 02:37 AM
floraelianor's Avatar
does it make a wierd sound or just the head light grear is not functioning?
__________________
1997 TA. Ram Air, 17"wheels, Borla 3" exhaust pipes, supper light Wilwood brake kits
1973 455 SD TA
Old Sep 16, 2006 | 09:34 AM
It is just not coming up, no noises
Old Sep 18, 2006 | 01:30 AM
Had the same problem. I changed the gear and it did not work. the problem was from the Headlight module located just above (the driver fender) or litle bit behind the air filter box. On way to make sure that the Headlight module is the problem, try to connect the left headlight electrical connection to the right and viceversa. If the driver side is working and the other one is not then definitly the problem come from the Headlight module. In my case, I had a bad IC connection on the board of the headlight module.
Old Sep 18, 2006 | 06:47 AM
TY I will check it out
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Dec 4, 2014 11:56 AM
