Sudden surge/lag in power...
Old Aug 31, 2006 | 10:51 AM
Bayer-Z28's Avatar
I was on my way home the other day and the car just started pulling for no reason. I hadn't changed the throttle position, it felt like I was driving w/ the ebrake on slightly, then was let off. -Car was in a good mood I guess.
And the opposite happened the other day. Was on my way home again and the it felt like I was towing somehting all of a sudden.
Any ideas??... I think it's about time for a new fuel filter. Could that be it?
Old Aug 31, 2006 | 10:58 AM
soul strife's Avatar
Re: Sudden surge/lag in power...
Yep, change the fuel filter. Also, check your plug wires, plugs, air filter, coil packs. First, do a simple check on everything. Can't hurt ya know.
Old Aug 31, 2006 | 12:42 PM
skifast87's Avatar
i agree with the man above sounds like a fuel filter
Old Aug 31, 2006 | 02:41 PM
Bayer-Z28's Avatar
Kewl... Still the OEM Filter. Bought the car w/ 19,500 almost 4 years ago. It's got 32k on it now. I DO have to clean my K&N, quite dirty. My NGK's have about 10k on them.. about time for new ones there...
Thanx guys...
Old Aug 31, 2006 | 05:38 PM
Rebelphotog96's Avatar
Thanx guys...
Also, make sure the MAF is clean. That was the problem with mine. Especially if you're using a K&N, if not oiled exactly right, the oil can also get on the MAF and cause the same problem. If it looks corroded/dirty at all, just VERY CAREFULLY and lightly scrape the wires clean, or get some electrical contact cleaner or something--not really sure what--and clean the sensor wires.
Old Aug 31, 2006 | 06:19 PM
skifast87's Avatar
Im gonna be honest with you. 10k on a set of plugs is nothing I dont know much about NGK but most plugs should run any where from 40 to 60k. If i were you befor you go out and buy new plugs check to make sure the ones you have are gapped correctly. Also just look at the general condition of them i would bet they are fine.
http://opc.mr2oc.com/online_parts_ca...park_plugs.jpg
I know its hard to read but the above link should help you guage the wear on your plugs.
Old Aug 31, 2006 | 06:26 PM
Bayer-Z28's Avatar
^ the NGK's are only good to around 10k miles. So it's prolly about time to change them. AC's, yes you can rack some mileage on.
I just hand polished my MAF last week. I could go in there w/ some alcohol and Q tips to clean it. It didn't seem dirty. I made sure I was xtra careful around the wires. I taped one of them, but it didn't move it at all.
Old Sep 1, 2006 | 01:44 PM
skifast87's Avatar
hmm i am glad you corrected me. Why is it that they only last 10K. Also is it worth the trouble to change them every year.
Old Sep 1, 2006 | 01:52 PM
Bayer-Z28's Avatar
No idea bro... I guess the performance plugs don't last long.
Old Sep 1, 2006 | 02:10 PM
skifast87's Avatar
hmmm well i guess it cant hurt to try them out
Old Sep 1, 2006 | 02:14 PM
Bayer-Z28's Avatar
I'm not sure on perofmance gains. I installed them when I did my LT's and catted Y. Also did Taylor Spiro-Pro 10.4 race wires. Maybe 5hp...
EDIT/Update. I cleaned the Filter and MAF. The MAF was a LOT dirtier than I thought it was. Would rotating the MAF have any different effects on fuel mileage or driveability? The partition is normally verticle, what if I rotated the MAF so the partition was horizontal?
Old Sep 1, 2006 | 05:32 PM
skifast87's Avatar
Yeah i dont think it would do much for preformance. I dont have any issues with the ACD's in there right now car runs smooth and great. just wondering if it got any better i guess.
Old Sep 1, 2006 | 11:57 PM
AL SS590 M6's Avatar
NGK tr55s are a copper plug and should last in a properly tuned motor for about 30k. The reason that copper plugs go bad faster than platinum is that the copper burns away slowly during normal usage.
Old Sep 2, 2006 | 12:20 AM
Bayer-Z28's Avatar
^ I had my car tuned by a reputable tuner/installer back home. All the mods I have now, minus the susp mods, were all in the car when i had the car tuned w/ LS1 Edit by EastSide Performance. "LS1 Edit Tuning Specialists" They did a 300hp dual stage nitrous shot in a 383 motor... Also in GMHTP
http://www.eastsideperformance.net/
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
jayblev95
Sep 26, 2015 09:44 PM
4586
Aug 24, 2015 11:04 PM
