Need info/opinion on Baer Brakes for 97 SS Camaro
Old Aug 29, 2006 | 04:31 PM
TomcatMF's Avatar
I have a 1997 Camaro SS that I was thinking of installing a Baer brake kit into. I want to put in the 13" GT system. Most sites have the kits that only have the front rotors, but I really want to replace all 4 rotors. I don't have much experience working on brakes myself, but is this something I could tackle on my own, or should I have a pro shop do the work? Thanks
Old Aug 30, 2006 | 12:04 PM
CALL911's Avatar
Re: Need info/opinion on Baer Brakes for 97 SS Camaro
I let a shop install my Baer brakes. After seeing the fabrication that was needed to mount the calipers, I was glad I made my decision NOT to do it on my own.
Old Sep 11, 2006 | 05:49 PM
Severous01's Avatar
tell you what...find a sawzall, 2 blades, 1 can of wd-40 or other lube. spend about 20 minutes on each cutting off ears and tabs. use brake cleaner and spray it off and paint whatever color you want. save the hundred bucks.
Old Sep 11, 2006 | 07:46 PM
OBE1 95Z28's Avatar
Installation is straight forward, I installed the Baer 13" Track Kit. No need to upgrade the rear brake setup, it works well. Just add some better pads like the Hawk HPS.
Old Sep 12, 2006 | 10:24 AM
Bud M's Avatar
Its pretty much like Severous said, a sawzall and a few blades. Keep the cut lubed and the blades will last longer. The instructions that come from Baer are pretty thorough. The only downside to Baer is that replacement rotors are really expensive. If you go with a C5 brake kit the rotors are much less expensive.
Old Sep 13, 2006 | 09:01 PM
Severous01's Avatar
i have the c5 kit and couldnt be more satisfied. both are a PBR caliper and made by the same people, using the same abutment brackets and the same pads...the only expensive part is their rotors.
i'm happy with my 20 dollar C5 blanks and red calipers. i found some brembos that were for sale on ebay for a hundred bucks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
slocody
Feb 10, 2003 01:04 PM
