Need help ASAP with ABS system!!!!
Old Aug 25, 2006 | 05:32 PM
zkmfdmz's Avatar
Exclamation Need help ASAP with ABS system!!!!
I am replacing the ABS motor pack on my 1995 3.4 camaro. In the instructions from ALLDATA it says i need to release the tension on the motors using a program on a PCM/ABS scanner. I do not have access to one nor do I want to pay 300 bucks to pay a shop in labor. Is there any way to release the tension on the motors without this? Are the motors ALWAYS tense?
Would disconnecting the battery cause the PCM to release the tension also?
I need help ASAP thanks.
Old Aug 25, 2006 | 10:18 PM
84firebird's Avatar
Re: Need help ASAP with ABS system!!!!
http://web.camaross.com/forums/showthread.php?t=467892
check that stuff out, the susp brakes forum has some of this abs in it
Rod Bender
Nov 7, 2023 02:30 PM
Heathen1
Jan 2, 2016 04:27 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
squarehead
Jan 15, 2015 07:02 PM
