What brakes should I get and Will C6 brakes work on my 00 Z28?
Old Aug 24, 2006 | 09:24 AM
Evil LS1's Avatar
I saw in the GP that you can use the brake brackets for the C6 calipers too.
Here is the story on my car.... 2000 z28, 383 stroker, 461 rwhp, used for SOLO I and SOLO II AX events. Car is heavy, 3800# with me in it and has full interior and working ac.
Currently I run stock rotors and calipers with hawk HT10 pads on the Solo I events and Hawk HP+ pads for solo II and street use.
I CAN NOT induce ABS no matter how hard I push the brakes when I am on my V710 r compounds running Solo I events. Therefore I need more brake!
So, what will be best??? Wilwood? C5? C6?
I am running 17x9.5 Konig Monsoon wheels and have a lot of clearance between the spokes and the calipers.
I already have Stainless lines front and back and want to know if I can run them with the vette brakes??
Down side to wilwood seems to be price and no dust shields. Will they stop much better than the vette brakes? How much better?
thanks
Brad
Old Aug 30, 2006 | 03:33 PM
Severous01's Avatar
Re: What brakes should I get and Will C6 brakes work on my 00 Z28?
you can bolt the c5-6 calipers directly to your existing spindle. you'll have to use the camaro/ta rotors though. you could also get the bob bishop setup and use either c5-6 caliper with the c5 rotor.
Old Aug 30, 2006 | 07:17 PM
jfman's Avatar
What is the bob bishop setup ?
Old Aug 30, 2006 | 10:11 PM
96HawkCnvt's Avatar
I've been running Wilwoods for street/track for years and the lack of dust shields hasn't presented any problems. I've got a 4 piston setup vs. their 6 piston but the idea is the same. They work great!
Todd
Old Aug 30, 2006 | 10:39 PM
jfman's Avatar
Todd
On the stock rotors ?
Old Aug 30, 2006 | 11:18 PM
96HawkCnvt's Avatar
No, they are 12.2" x 1.25" 2 pc vented rotors.
Todd
Old Aug 31, 2006 | 01:57 PM
Diognes56's Avatar
Good to know .
David
ddr698
Jan 9, 2015 10:05 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
blac94Z
Dec 7, 2014 08:40 AM
